Nissan Skyline GTR R32, 47000kms, Group A, violet purple, heavily modified, Ray's Engineering wheels, immaculate condition, 3 year warranty optional, $30500 negotiable, BNR-32R. DL-19135. Japstyle Imports PARRAMATTA 0410-06 2145
whats a group a gtr?? i know of the group a racing division, that the gtr had to be made in production for but was there a group a gtr from the factory. or a gtr with a group a engine.
what sort of specs does it have??
how do you know if your car is a group a??
the dealer told me that mine was a group a but i thought he was just bullshitting
on my rego the model is r3292a. does that mean anything?? can you guys check your rego papers to see what it says.
the dealer said its a group a cause the engine no ends with a "a". i just thought he was making it up. he said that the group a has about 280hp over 250hp of a standard gtr.
ive searched everywhere and cant find any info on it.
thanks
josh
https://www.sau.com.au/forums/topic/41500-group-a-gtr/
ive search everywhere and founf nothing so i think the dealers on this one and my one and just making shit up
Yes, talking shit for sure...
Evo_Lee got it right, the only "Group A" type R32 GT-R was the Nismo version (for Group A homologation)
https://www.sau.com.au/forums/topic/41500-group-a-gtr/#findComment-853558
To be some sort of Australian delivered group A, it needs to :
*Be an Australian delivered GTR. Since 'Group A' reffers to that period and category of racing.
*Have a diff and trans oil cooler standard
*Have the 260kmh speedo
*Have an aerial on the roof
*Have the Nissan 'hamburger style' badge on the bonnet.
https://www.sau.com.au/forums/topic/41500-group-a-gtr/#findComment-857079
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
