I've noticed on my car a weird bumping / knocking? noise when I get off the accelerator. I've attached a sound recording of it, almost straight away there is abumping noise in amongst the road noise, best I could get by putting my iPhone in the back seat and doing a voice recording. Does anyone have any idea what it might be?
Memo.mp3
https://www.sau.com.au/forums/topic/415164-bump-in-left-rear/
Checked my car this morning, the wheels nuts on the left rear were loose, haven't been for a drive yet to confirm that was the noise, but I'd say it will be. Glad it might have been a simple problem to fix. Terrified that wheel nuts were loose, will be keeping an eye on that.
Could have been due to the centre hole size of the wheel being too large for the car. Don't actually know what it's called, but had this issue on my civic and it basically rattles the wheel nuts loose over time. I just went into Bridgestone and got rubber spacers that pack the around the centre hub bit to make a perfect fit for the rim, did the trick and was $30 fitted on the spot.
Hope that helps if it's a recurring issue!
As others have said, it sounds like you might be missing hub centric rings.
The studs affix the wheel to the hub but the centre bore locates (centres) the wheel.
The centre bore of a skyline is 66mm, and you will need hub rings or as mad082 said "egg rings".
They are available from ebay, you will need to check what centre bore the rims have and get the corresponding ring to fit over. For example Enkei RPF1's have a centre bore of 73mm therefore you would need a 73/66 ring, however make sure it is for a Nissan, cause other cars have a similar bore e.g. Holden has 66.9mm.
Edited by Grimesy
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
    • Fair enough, I am in no way a tire expert so I'm not familiar with all the terms and conditions. I'll definitely note down the AD09 to potentially try in the future. Rain is not too big of a concern for now as I will probably only drive in the rain when I have to. And considering I still lack experience driving the GTR I'd more than likely take it easy too. I have coilovers in the car but as I barely got to drive so far I never bothered to even check if they are adjustable haha. The suspension is almost entirely old and worn as well so I suppose when I eventually fix that in the future that would make a huge difference.
    • There's not a great deal to report here .... except ...... FOR .... LSD!!!  I bought a Quaife LSD from the UK and shipped it here .... Wish I'd just bought locally cause the shipping and duty was $700! But there were so many diffs used in the E90s I just wanted to be absolutely certain I was getting the right one so I spoke with a supplier in the UK who builds race cars and they have heaps of experience with the E90s.  I pulled the diff out which was seriously awesome - I've never done anything like that before, I must have watched 1000 videos on YT about it as well as consulting the Bentley manual. It was super easy in the end. The diff was delivered to the awesome folks at Hornsby Diffs and will be back in a few weeks. I also replaced the diff bushings with some Nolathane ones.  Really looking forward to getting it back and getting back to the track or even the skidpan.
    • yeah... the 13kg/mm springs weren't always in there, I had 10kg/mm but doing a few SMSP commanded heavier front springs. It's so good now going into T1 and T2, just need more seat time and real tyres.
