That looks awesome mate thanks for that! Ive just ordered mine and so far jdl have been great to deal with. Should have them in about a week and will keep you all posted when i fit them
Dan is a great guy! Very easy to deal with! I hope you don't get smashed at customs like myself :(
I have done them similar for the GTR in the past but haven't taken any decent photos
Problem with the skyline is that there is so many different rotor diameters people use and making them a one size fits all is impossible to do so they are neat and effective.
I've got a set to do next week on a GTR with ex touring car brakes and 378 mm rotors.
Would they fit the Alcon Advantage Kit as well? Would you concider making more?
I can do them to suit the Alcon kit yes.
Every brake kit is different due to rotor size and calliper offset.
They won't be beneficial at all for a super sprint type day. Your brakes would be struggling to get to optimum temperature before adding effective ducting.
The FT86 did a 1hr enduro at Bathurst yesterday and the brakes lasted perfectly.
Yup, it is the full kit for front and rear with Calipers, Hats, Rotors, brake lines, fluid and pads.
Oh ok..What you recommend putting in for street and track use? Something like a a1rm/hc+ pad. Or do you have to stick to a alcon specific pad? Man i got stung with the import tax as well.. $773 >_< they should be on the doorstep tomorrow
Spewin :( Its hard to hide with 4 boxes THAT big though! haha.
Jack in VIC ran this kit and was running PAGID pads. Can't remember off the top of my head but black and yellows ring a bell. I've had awsome results with Endless CC-RG and MX-72's on both my car and mates cars.Work out of the drive yet almost throw you through the window! I think the stock pad are Ferodo 2500's. OK on the street but for a big heavy car with grunt like a built GTR.... doesn't really work.
Anyone had any experience with ATTKD brakes? Had a look at them yesterday at Just Jap and according to them they are the same as D2's, however the 330mm kit has 6 pistons instead of 8:
http://justjap.com/store/product.php?productid=20986&cat=285&page=1
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
