Hey guys,
EOI, Don't want to sell, but will swap for the right car.
Would really like a R32 GTR in good condition.
Or Stagea M35 wagon. Or something along these lines.
Car:
R34 Series 1 GTT
Turbo
Manual
AR2 Red (rare color)
low Ks,
Just serviced.
Mods,
Turbo Back 3" Exhaust.
Intercooler. (Return flow, NO HOLES!)
HKS Panel filter.
Will through in GTR Front bar (not fitted)
Apart from that, stock as a rock. Not boosted. Still runs 5-7 PSI like the R34's do.
Not an issue with the car at all, Really is Immaculate. Any tests welcome.
Zero434 496 747
Will Supply RWC if needed, has Rego till 03/13.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
