  • Replies 45
Hi mate just wondering if you have the passenger airvent and the windscreen vent
passenger airvent went with dash sorry and windscreen vent is sundamaged and broken in a couple places so not worth selling.
what colour is the compliance plate on the car ? purple or green. interested in belts but the answer to the previous qustion will tell me if i want them or not.
Will let ya know this arvo
UPDATED - couple more parts found and more pics below
Rear ash tray
Glovebox (missing the button)
Boot hinges - perfect working order
Bonnet release ; cable - working
Air con and clock front cover ***********FOUND ORIGINAL AIR CON BUTTONS LAST NIGHT, PICS TO COME
UPDATE ON REMAINING PARTS - CAR WILL BE TOWED WITH ALL UNSOLD PARTS THIS WEEKEND!!
Immaculate LED rear lights - finished in gloss black $150 pair
KYB New SR lowered springs, shocks and struts. Very nice firm ride, good condition front and rear $250 for full set
LSD - good condition, stock R32 gtst automatic lsd diff - $100
Strut braces (front and rear) polished alloy $100 pair / $75 for one
Racepro brand new never used manual boost controller - RRP $270, Will accept any REASONABLE offer
Racepro brand new never used blow off valve - RRP $229, Will accept any REASONABLE offer
3inch cat back standard exhaust, exits with twin 2.5 inch tips - $150
Front headlights - good condition, no cracks in glass - no bulbs $50 pair
Front nolothane control arm bushes - $50
Rear quarters (not cut yet - whole shell is good from firewall back) $150 each quarter cut or $350 for complete rear cut (boot lid sold)
Rear Front and rear wipers - working - $40 front pair, $20 rear
Windscreen wiper motor - $50
Standard brake booster and master cylinder - $50
L & R visors - with mounting brackets (pair) -$20
Rear vision mirror (with mounting brackets) -$20
Lower sill trims (pair) -$40
Interior light - excellent condition, no cracks in plastic cover - $15
L & R interior A pillar trims - $20 pair
Rear quarter internal c pillar trims very good condition - $80
Rear quarter interior trims / door cards very good condition - $80 pair
Rear seats complete good condition $50
Front seats - not matching trim cloth, driver's seat in good condition, passenger seat is in average condition - $20 pair
Seatbelts
Working Instrument cluster 150k on clock - $50
Rear ash tray
Glovebox missing button
Aircon buttons and fascia -$20
Working bonnet release and cable -$25
Boot hinges working - $20
Images - http://postimage.org/gallery/8wea5cu6/
LAST CHANCE NEED CAR OUT OF GARAGE AND WILL TOW BY SUNDAY.
$200 for strut braces and suspension.
Don't need them but good to have spares.
and you're going to throw them out this Sunday anyway right?
funny **** :) have PM'd ya an offer
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
    • It was picked up on the MOT/Inspection that the offside front wheel bearing had excessive play along with the ball joint. It made sense to do both sides so I sourced a pair of spare IS200 hubs to do the swap. Unfortunately I don't have any photos of the strip down but here's a quick run down. On the back of the hub is a large circular dust cover, using a flat head screw driver and a mallet I prised it off. Underneath will reveal a 32mm hub nut (impact gun recommended). With the hub nut removed the ABS ring can be removed (I ended up using a magnetic pick up tool to help). Next up is to remove the stub axle, this was a little trickier due to limited tools. I tried a 3 leg puller but the gap between the hub and stub axle wasn't enough for the legs to get in and under. Next option was a lump hammer and someone pulling the stub axle at the same time. After a few heavy hits it released. The lower bearing race had seized itself onto the stub axle, which was fine because I was replacing them anyway. With the upper bearing race removed and the grease cleaned off they looked like this The left one looked pristine inside but gave us the most trouble. The right one had some surface rust but came apart in a single hit, figure that out?! I got a local garage to press the new wheel bearings in, reassemble was the opposite and didn't take long at all. Removing the hub itself was simple. Starting with removing the brake caliper, 2x 14mm bolts for the caliper slider and 2x 19mm? for the carrier > hub bolts. I used a cable tie to secure the caliper to the upper arm so it was out of the way, there's a 10mm bolt securing the ABS sensor on. With the brake disc removed from the hub next are the three castle nuts for the upper and lower ball joints and track rod end. Two of these had their own R clip and one split pin. A few hits with the hammer and they're released (I left the castle nuts on by a couple of turns), the track rod ends gave me the most grief and I may have nipped the boots (oops). Fitting is the reversal and is very quick and easy to do. The lower ball joints are held onto the hub by 2x 17mm bolts. The castle nut did increase in socket size to 22mm from memory (this may vary from supplier) The two front tyres weren't in great condition, so I had those replaced with some budget tyres for the time being. I'll be replacing the wheels and tyres in the future, this was to get me on the road without the worry of the police hassling me.
