Quick update..
LS2 Coils mounted on plug with some alloy brackets I made up..
539563_10153069176310352_1249725365_n.jp
Head torqued down, 6boost bolted up and with a fresh ceramic coat..
544477_10153069174830352_1244696608_n.jp
Intake side all bolted up and throttle stops adjusted.. what a mission!
1012447_10153069174690352_572963677_n.jp
Also installed some extended studs up the back and replaced a dodgy wheel bearing I discovered..
1012914_10153069175100352_1021751994_n.j
I'll also be replacing my Tein's with Nismo struts and springs I picked up.. Should give a nice compliant ride and help with grip..
Just need to order my turbo and injectors and then i'll be dropping the motor in..... Exciting times hopefully soon!
  • 5 weeks later...
Dillon.. Its a Nismo lip.. CarMate and other bodykit shops sell reps of them.
Quick update...
Painted my cam covers in gloss black.. thought they came up ok for a rattle can job :D
1230086_10153205512045352_1713859998_n.j
Sourced some 2000's and extension adaptors, love the purple..
1185580_10153205512320352_2132308762_n.j
Picked up my precision turbo also...
1239428_10153205512125352_1486804305_n.j
Fitted her up..
1238794_10153205512420352_1597807329_n.j
Chucked the flywheel, clutch and box on the engine and dropped it into the car..
1233451_10153205512520352_956881474_n.jp
And mounted my exhaust ready for a dump pipe to be made up..
1236974_10153205512650352_1154312727_n.j
I also hooked up my fuel system and completed all the fitment of my fuel lines... did a pressure test up to 100psi and no leaks :D super happy. Not long to go now, just need tyres, cooler piping, a dump pipe and some sensors and we'll be golden.
Happy to say she fired up 2nd hit of the starter :) Sounds nice and tight. Car is off to get the dump pipe made up then its straight to work and onto the dyno for a light tune.
Im now running a Haltech R34 GTT Pro Plugin ECU which is due to be released to the public in the coming months. :) Along with Haltech's new CAN Wideband O2 box which will be released at the same time. Very cool stuff.
This was turn-key off an RB26 base map set at 3350cc capacity, flex fuel compensation enabled and injector flow rate at 2200cc. Not bad at all :D
It was dumping from a 90 degree 4" elbow i just clamped to the back of the turbo :D Car is having a dump fabbed on Tuesday.
Dave, ill be sharing the tuning duties with Scott. I'll most likely attempt most of it with his guidance, then let Scott work his magic in the high load parts until I've got some more experience under my belt. :)
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
