Hi All,
I've been searching around for days trying to figure out if there is a way to confirm that the engine in my car is the original one that came with it. The trouble is that the engine number does not appear on the build plate, in Nissan FAST, or even on the original sales documentation from back in 1993. I can confirm that the engine number matches the SA rego, but that really doesn't mean bugger all.
I've called Nissan and as it's not in their FAST software they can't help. Seems quite a few people run into this but I couldn't find any answers on if they were able to work it out.
Thanks in advance,
Jeff
I never worked this out for sure, but what's the first few numbers of the engine number?
Helps work out if it's *not* the original engine, e.g. RB26-042xxx would be from a 1994 according to: http://www.webbersrbguide.com/index.php?option=com_content&view=article&id=47:engine-number-register&catid=42:engine-number-registers&Itemid=2
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
