This morning I took my sons wheel to Bob Jane (coz its close) to get a puncture repaired. And i'm going to need tyres when my wheels get here in a few weeks so I thought I might as well get a few prices. My wheels will be 18 X 9.5 so this is what he told me.
Pirelli $570 per tyre
Hankook $370
Falken Under $300
My question is what are your thoughts on all or one of these types of tyres or maybe even another brand. Start typing.
Thanks guys
Alan
https://www.sau.com.au/forums/topic/41556-which-tyres/
Falkens for under 300 are probably the 326s i have on mine ... not very good for a GTR... probably ok for a low powered gtst or a falcadore...
i have 18x9s... i got quoted 650 a tyre for michelon sport pros or bridgestone S03s.. or about 500 a tyre for Yoko ES100 (i think thats the model)...
Leaning towards the yoko, because i can't justify 2.5k on tyres...
https://www.sau.com.au/forums/topic/41556-which-tyres/#findComment-852066
I have got the Yokohama ES100s on my 18x9.5" rims. They fit real nice and so far have been a good tyre. As ferni sad the Falkens you were quoted on would be the 326s and I haven't heard anyone say good things about them. For an extra $100 a corner you could get the Falken ST 115, They are supposed to be pretty good. Alot of good things have been said about the Bridgestone SO3s and the Michelins also. It all depends on what you expect from the tyre, the size of your wallet and if you have a brand preference. I have always liked Yokohamas so it was either ES100 or V102 for me, and since the hole burning in my wallet was getting quite large I chose the ES100, and so far they have easily performed to my expectations.
https://www.sau.com.au/forums/topic/41556-which-tyres/#findComment-852232
no idea mate, i have not bought them in Australia b4. I used to run P-Zeros overseas in Malaysia. But looking at the Pirelli website, for that size, u'll be needing the P-Zero Asimmetrico tyres. Melb dealer is Bob Jane (03) 9329 6311 according to the page.
The P Zero system concept
- P Zero Direzionale front, P Zero
Asimmetrico rear
- P Zero Asimmetrico all round
PZERO DIREZIONALE™Size range
35
255/35 ZR20TL 97Y(J)
40
225/40 ZR18TL 88Y
235/40 ZR18TL 91Y
45
215/45 ZR18TL 89Y(F)
225/45 ZR17TL 90N2
245/45 ZR18TL 96Y
PZERO ASIMMETRICO™Size range
30
285/30 ZR20TL 99Y(J)
295/30 ZR18TL 94N3
35
265/35 ZR18TL 93Y(1)
335/35 ZR17TL 106Y
345/35 ZR15TL 95Y
40
245/40 ZR18TL 97Y
255/40 ZR18TL 95Y
255/40 ZR19TL 96Y
265/40 ZR17TL 96Y
285/40 ZR17TL 100Y
45
205/45 ZR17TL 88W
225/45 ZR17TL 91Y
245/45 ZR16TL 94Y
255/45 ZR17TL 98Y
255/45 ZR17TL 98Y(F)
255/45 ZR18TL 99Y
255/45 ZR19TL 104Y
285/45 ZR18TL 103Y
50
205/50 ZR16TL 87Y(A)
215/50 ZR17TL 91Y
235/50 ZR17TL 96W
245/50 ZR17TL 99Y
255/50 ZR18TL 102Y(1)
https://www.sau.com.au/forums/topic/41556-which-tyres/#findComment-852957
How about, if money is tight, Falken 451's. Theyre about the cheapest I would go and say 245/35/R18 all round shouldn't be more than $270 per tyre.
Theyre pretty decent for a cheap tyre and it will give you time to save up for your next set of better tyres.
https://www.sau.com.au/forums/topic/41556-which-tyres/#findComment-855970
I just bought Yokohama ES100s today, the guys are putting them on as we speak!. They are $255 per tyre, but I have stock rims so i had to get 225/50Z R16 92W.
I wanted to get 255s but they don't come that wide for a 16" rim. I wanted the 45 ratio tyre wall, but apparently for my type vehicle it is too small and illegal, due to the weight. Which i wound strange as it was 225/45Z R16 92W. But 50Z is ok.
The V102 was on an extra $50. I was considering these, but the difference is minimal and the ES100 is such a good performer that i could justify the extra $200.
https://www.sau.com.au/forums/topic/41556-which-tyres/#findComment-857831
I think the Toyo Proxies T1-S are a bloody good tyre for the price you are paying for them.
Great in theory but they dont come in 18's.
Big fella - it depends on funds but if it was me I'd get firstly the Yokohama AVS Sport (V102's) or else the Falken ST115's.
https://www.sau.com.au/forums/topic/41556-which-tyres/#findComment-857911
I have the top model hankook's on my R33 gts-t in 265/35-18. I think they are good, but not for a hy-po car. Maybe if I had about 180-190rwkw they would be ok, but with 210rwkw I find that I can't get any traction when I put the foot down. Will start another thread about my problem as I'm looking for a solution.
https://www.sau.com.au/forums/topic/41556-which-tyres/#findComment-864549
OK... time to tell my story.. my old man been in tyre business for 26 year nows, so therfore i have personaly try all kind of tyre which you can name it. For me my personal tyre is bridgestone which is value for money, but i have also try Pirelli before which is very good, even on the low end version (Pirelli), however because of the $$$ that y i choose bridgestone for my personal preference tyre. Yokohama well i have try the AVS which turn out "SUCK' as comparison to other brand for the same value.
https://www.sau.com.au/forums/topic/41556-which-tyres/#findComment-884536
Value and performance, IMHO the Toyo trapio TPG (GU:WN) is pretty hard to go past. Quite sticky wet and dry.
See if you can get 245s fitted, 'but I have 9.5 inch rims, 245s wont fit' think again. I have seen them on a 10" rim. If you go slightly undersized on the tyre, it will give more rigidity to the sidewall, giving a better feed back and more stability on the road.
Yet another opinion, have fun making the selection. :D
https://www.sau.com.au/forums/topic/41556-which-tyres/#findComment-885690
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
