got a metal inlet/exhaust gasket kit, few speedflow fittings, oil pump and gasket ahead of the weekend. No fkn way im gonna be pulling this motor out again lol. On that topic, anyone got a black heater hose kit for 32 gtr laying round?
All good man, Im really after the hoses under the plenum as i vaguely recall someone telling me they split in their old age...
Or maybe after watching your car piss coolant at the calendar cruise i realised that sucks and i'd rather not have to pull the motor again :)
split dump is fouling the wastegate for some reason.
dunno why... it worked fine for ages, now i cant grind enough out to make it work, ill grind through.
wtf happened? dunno.
Time to get a bellmouth dump, maybe all new system.
7 hours and no luck...
you need a break, eat & drink for brain power, do some reading on the forums, and the solution/problem will become clearer.
We had the works !
Drinks and Rob (Not a Pulsar) on the phone giving us guidience, also Google was a bit of a mate on the night.
A lot of it was testings up the road so pulling in and out = sucked. But, some boys on SAU reckon they've got the fix. My Spark plugs may not be "gapped". So will check that and HOPEFULLY it'll stop misfiring.
Trying to figure out Overheating when sitting above 110kph..
Fresh coolant and clean, no luck..
New thermostat and more coolant. time to test again, fingers crossed.
Slight change in temps across radiator, so maybe some minor blockage there, look into a proper flush next, or just upgrade it as I want to do that anyway..
got motor out, changed all the water hoses and inlet gaskets, removed the remainder of the wtin turbo water and vacume lines that arent used and tidied up the engine bay a bit. pretty productive, not as much as id hoped though :/
no wheels for me tomorrow so yall have fun without me
Are you painting them another colour?
I really wouldn't mind painting mine
I was considering painting the centers Black but after the enormous sh!tfight I've had stripping them I might leave them as is.
I do like the result alot. You reckon I should paint Black or not?
Much better than the uneven goldish crud they had when purchased. (SAU Third or Fourth Handies)
Crimson Inc. Linea Sports (made by Sparco)
post-78856-0-06591100-1363429754_thumb.jpeg post-78856-0-48300000-1363429506_thumb.jpg
I have painted some R32 GTS-t rims before and it was a heap of fun. Not bad result either.
Looks good. Painting those wheels black may be too unnoticeable. How much did all the stuff you need cost? Im convinced I must do this now.
Any ideas what colour wheels would suit maroon?
So far the paint stripping exercise has cost me less than $40. Paint stripper gel and wire brushes. I bought some brushes to use on a drill but they got little use. Hand job FTW!!!
The painting of the GTS-t rims was all done with cheap cans from Supercheap (except the primer) but if I do it again, I would use better paint like engine enamel as it should be tougher and longer lasting.
OT. I washed my car and drove it to "WHEELS" at the Racecourse. With the wind and dust, it is dirtier now than before I washed it! :(
Show pics of car with rims you want to paint for colour choice suggestions... Black, Gold or Bronze should be good with Maroon though. :)
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
