Do it on the side until you start making to many clients and turn full time :D !
Would a carwash place (Machine thing - like the ones at the petrol station - Likes Waves at Gunners) will that damage my paint work? I have a few bits of paint scratches and 1 rust spot - would a high pressure gun / carwash machine peel the paint?
Edited by Jeremy90
Sinister, you put up a number for a bloke from Tire wholesalers a while back, for mike or mitch or something? Well actually have money for tires now and I can't find the number.
Thanks mate. I'll become a member soon, just so I can throw the '33 down the tarmac a couple of times. Found some PZero Neros for cheap, so they will last me until the end of the year...
Started stripping it, and removing obsolete bits. (aircon pump finally gone)
In preparation for new injectors, timing belt etc, waterpump, Z32 afm, fancy timing gears, Nistune, radius rods, and a clutch.
And some little things like a battery isolator, re do the gauge mounting, some more stickers etc.
Wow - getting stuck into it Michael. Rip it all out maaaaate
No aircon ?? - you setting up a track car ??/
well I did the usual when I got back from Belco ghetto (washed/polished the cars).
Then decided I'd do something really simple - remove the cabin rear view and paint the back of it black.
Fark me while removing I broke the friggin mirror in it didn't I. *&^%$ Live n learn....
Oh oh oh - the bonnet came up like black glass today :D
Spewan! (mirror)
Aircon just made it overheat, but i am making an extinguisher bracket for track days.
Wouldnt take much more though... some brakes and a seat.... hmmm. I need to keep it road legal. And have a loud stereo.
If i was going full track car id strip it to nothing, then build up with a plan. One day.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
