Same when I got it back eventually. Dropped a packet on suspension.
Steering components were in great nick luckily.
I've had to replace basically everything suspension wise on the GTR and it wasn't cheap but a lot of those things were more expensive than what I paid to get things done.
I think great to get all that stuff refreshed on such an old car.
My GTR is an 89 model and when I bought it in 2005 the first thing I did besides get a major service done was drop like $3k on the suspension. Well worth it but I'd just double check these prices that you have :)
ive barely spent anything on suspension.
adjustable front and rear camber arms.
adjustable castor arms.
new rack end.
new rear tie rod ball joints.
hicas eliminator.
thats it so far.
should do subframe bushes and try and source new bushes for coilovers, but eh, when I get there.
Did you notice a big difference when you got all that fixed up Kat?
f**king oath.
I bought the car at a good price knowing it needed a buttload of work though.
There's been a few other times when shit has broken over the years and I could REALLY tell the difference before/after the fix.
  • Like 1
Took Rosie in to get coil overs done - missing bush in one of the coil overs (Couldn't do it) so requested to do brakes - They didn't have time to do it. So got Rosie back with no work done ($50 labour fee so pretty much paid $50 to park on the southside). Few days later got a quote on all the work that needs to be done due to tare and wear, as follow; I guess with the below all done and fixed that's everything for suspesion and steering also, all the parts that are being replaced are from factory from my understanding so 15 years worth out of a part is fairly decent I spose:
LAB 7.00 LABOUR $100.00 $700.00
WA - FOUR 1.00 FOUR WHEEL ALIGNMENT $90.00 $90.00
SPF1811K 1.00 BUSH - CONTROL ARM UPPER/ OUTER F $205.75 $205.75
SPF1484-21K 1.00 BUSH - SWAY BAR MOUNT - FRONT $22.67 $22.67
2.00 SWAYBAR LINK - FRONT GENUINE $68.00 $136.00
54618-85E00 & 54668-85E00
2.00 STEERING RACK END - FRONT - RE844R $39.91 $79.82
2.00 TIE ROD END - FRONT - TE926-12 $29.20 $58.40
2.00 HICAS BALLJOINT - REAR 55154-30P01 $155.00 $310.00
1.00 HICAS LOCK BAR & TOE ELIMATOR $325.00 $325.00
SPF1485-18K 1.00 BUSH - SWAY BAR MOUNT - REAR $27.53 $27.53
SPF2667K 1.00 BUSH - SWAY BAR LINK PIN KIT - REAR $24.69 $24.69
ENV 1.00 ENVIRONMENTAL WASTE DISPOSAL LEVY $5.00 $5.00
WSS 1.00 WORK SHOP SUPPLIES & CONSUMABLES $8.00 $8.00
TOTAL: $2,200
seems like a lot, as kat mentioned, get it looked at elsewhere.
  • Like 1
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
