Stripped everything off the front.
And getting the headlights straight and even. Trying to fix the whole front and get it all straight. Takes a lot of patience.
Next, the bar has to go about 10-15mm to the left.
Replaced my Rocker Cover Seals and put on my Shinyish R34 Rocker Covers.
In the process. I painted a couple of pipes n things Black and cleaned up my Exhaust manifold heat shield with a wee bit of sanding.
post-78856-0-88128000-1379755268_thumb.jpg post-78856-0-79689800-1379755271_thumb.jpg post-78856-0-51385600-1379755275_thumb.jpg post-78856-0-20997700-1379755264_thumb.jpg post-78856-0-51090500-1379755266_thumb.jpg
Sounds like we all had a Productive Day with our Lovely Ladies. ;)
Bought and put on 4 New Hose Clamps for cooler piping. At $12.80 for 4, why wouldn't you? :P
Having driven to Autopro and back, I checked for oil leaks around the Rocker Covers... None as yet. :D
also took my Valley cover back off to make things a little easier for Trojan this week. :woot:
Stripping as much out of the engine bay as i need to clean and paint it.
And the rest i just push into the middle and cover with a dropsheet, like furniture in a house.
It will all go back neat and tidy, time to get rid of the mess.
The black and red looks good Rob.
I did ya Knob. :P
On Friday night, my TXT to you said in regards to your O2 sensor..."Bring it round tomorrow or Sunday. I'll pull the whole thing out and fix it properly."
Not Sponsored but I have a sticker. :laugh:
Trojan!
Done me some sweet deals. :thumbsup:
Rob youve inspired me to paint my cam covers and stuff, so i stripped more stuff out of the engine bay today.
Im thinking the black is good. More black and a bit of colour and shinybits.
  • Like 1
Sweet! I am considering going back to a Black Valley cover but I guess I can always Accessorise as I see fit.
A little Black Paint makes everything completely stock officer.
Originally I was going to repaint some Cam Covers I got but ended up swapping them for the shiny ones. :D
I did ya Knob. :P
I kid I kid haha :D
edit: I will try and find some more piccys :D
Edited by RosieR34
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
