About GTR boxes...
I look for RB25 engines and boxes as i want to do an upgrade one day. One thing ive noticed is that GTR boxes are about half the price of an RB25 box.
Usually about $900.
Why are they so cheap?
Im thinking of using one, if i can make it fit behind an RB25
Its always garaged , maybe soon we can go out for a cruise
Pretty sure I'm puttin a day permit on for this formal run/cruuse. Are you coming? We can head out and cruise together
GTR 32 boxes have smaller sinchro's. So if you go for a 33 pull type there is more expense in bits n pieces. (not just a push to pull conversion)
Could explain price difference.
Jimmy's GTR is really nice. Saw it for the first time today.
There was 3 at Shannons BBQ :D
Drivers window is stuck in the down position and swapping over to my old window module won't fix it, Half the functions on the module work, just not the window section. Off to the autoelectrician I go, I think theres something wrong with my door loom.
SkyWagon got her Front Shocks and Harder/lower Springs today. (Thanks Mik for the Tools!)
With other commitments thrown in, it took ages and especially those damn Bigass Nuts on the struts, what a bitch to undo, plenty of swearing but the ride is Sooooo Much Better. I think it's a whole 5mm lower. :laugh:
Tomorrow I'll do the Rears. :D
She also got some new wheel nuts, Center Caps, Valve caps and a Nice SkyWagStag sticker for the Kilowatts.
Just need to fix the exhaust leak and adjust the handbrake and we might be close to Rego name transfer...
post-78856-0-22616100-1386419151_thumb.jpgpost-78856-0-19450900-1386422407_thumb.jpg Black is Stock.
Got my inspection on Thursday.
Played around with the drivers door today and finally got to it close correctly.
Heading over to shanes place tomorrow and raising the coilovers.
Then all I need to do is cut the wire for the hicas light on the dash.
Chuck some roadworthy rims/tires on the car (I guess yours are gone Rob :/ )
Also put a stock exhaust on there.
Hopefully the list I get back isn't too long
Ohh and my R34 left Japan on Monday :D
Yeah Sorry bout that. :(
I might try to get some more tyres for the lendings...anyone wanna chuck in?
Take your cluster out and remove the bulb for hicas, no chopping.
Northwest in Fyshwick are pretty good for 2nd handies. (not the other kind of handies) :D
The spares that are now on the Wagon are 225/45? R16 and have passed several times. ;)
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
