i have been looking at an SAFC..
and yes :) a couple of months till I go power happy :)
fuel pump, injectors, coils, and more BOOST to start with :D
Edited by ..::R33GTS-T::..
I have a garage full of carbies.
Holleys, Mikunis, Dell'ortos
Gold. Its a good investment. :yes:
Killed a very big fat black widow making a home under the front left guard. The thing might have bit me as i want to work under there.
Saw it yesterday, found it dead today after gassing it last night. Im very relieved but a bit edgy, i keep feeling things crawling on me.
Arachnaphobia.
  • Like 1
I sprayed a big black spider crawling across the kitchen floor last night.
Not sure what it was but it was BIG.
I thought it was a mouse.
I don't like.
i don't like BIG spiders, the one that was living in my mirror was bad enough! having to get rid of the webs everyday :( i think i used half a tin to kill him haha
Back OT...
Got today, a New Exhaust Mani Gasket, a KA24 Throttle body (from a U.S. 240sx) and something that will become a front lip. :)
Since my last efforts on the Wags, she seems to be running alot smoother. :bunny: Not sure what fixed it.
Cleaning some Electrical Contacts? Different AFM? LUCK?
Might do Front pads soon and Get Extractors on. Also need to fix the speed sensor, (Speedo still intermittently craps out) and Temp Gauge (works in the morning but not in the arvo) - common problems.
oops 2 convos going at once
Bryce, what ECU? What have you done (for me) lately....eddiiiiieeeeeee
Played with intake piping at all? where and how does it cut?
Rob/New Guy
Not enough for R&R, Id say coils are past their best
Vipec V88 plugin as soon as you get on boost it cuts, but sometimes it does go past to about half bar if you trickly accelerate slowly. Hopefully changing my coilpacks will fix this issue. Will do a boost leak test tommorrow.
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
