Today was Power steering Fluid change day for the Wagz! Another first. :D
Oh and I bought a can of dark grey spray paint from Bunnings and gave the lip a hit.
Dodge yes but well... you know. Cheap car, minimal F**ks given.
Needs to be darker grey though. I will do it better one day...
and got this in the Post.
85% Rounded Nuts? No Problem.
Pulled the rear door trims off and secured some bits in there. Hopefully ridding the Wagz of Rattles.... still :/
and tightened the steering rack bolts better. (one was a little loose.) Hopefully fixing some steering wanders.
Block sanding, round 2.
It takes a while, each part has to be sanded in the correct way so there no grooves, finger marks, flat bits on curves, etc, and so the guide coat does its job.
Yes, theres about 12 or more different bits that can be the cause.
Its a total pain.
I hate how one bit looks like the problem, but its actually another bit that makes the first bit loose.
Feels like chasing your tail sometimes.
Even the experts can have trouble, from personal experience.
You got that right... I'll figure it out.
Today I pulled off the chrome strips on the roof and cleaned out soooo much leaves, sticks, dirt and crap.
I managed to put the strips back on properly so they actually sit right too.
This eliminated most of the rattles I've been chasing! :bunny:
I also put on an R34 Steering wheel I got for Cheaps on Ebay...
Wired up the horn, SRS Airbag is non functional and the indicators don't self cancel but they only really did 50% of the time anyway. Meh...
Looks and feels cool.
Wet sanded the bad bits with 400.
Coming up a lot better than i thought it would, now im confident the rest will be good.
Like the drivers door i thought would still be bad, but the crease at handle level only has a slight wiggle and a nick. Thats about 10cm of guesswork as it had a long shallow dent there.
There also seems to be a slight ripple on the flat underneath, very hard to see, it will sand out with some more primer filler on there.
The old "wet the panel and look" works well for spotting imperfections.
Patience helps too.... 3 hours to sand a door and a guard correctly. 18-20 for everything.
Edited by D.I.Y. Mik
  • Like 1
I can see why they charge so much for a good paintjob.
Show car quality is about 140-200 hours of work plus materials.
When you examine the process, its very hard to cut time or stages from the job, so even a cheap paintjob done properly is not cheap.
Even doing the easiest possible (not spraycans) paintjob id say at least 50 hours.
Washed it, drove to Goulburn.
Drove home with my Drivers side mirror glass in my hat.
I have actually seen that sort of stuff dripping in my mirror Rob! I never knew what it was.. Some sort of silicone or something.. Always see it after I wash the car.. That makes me worried now :/
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
