Sanded half the car again today as i used a dodgy bit of sandpaper yesterday and scratched it all up. >_<
Making a few mistakes then fixing it up makes it take a while, but im learning from each fk up.
I think i have the spraygun sorted out, but ill do final tests to make sure.
So finally now its all smooth, clean and wrapped up ready for a sunny day to put on the final coats.
Making a cattle grid type thing to take the dip out of my garage entrance, so the car can go over, but still have the water drain away.
I'll take some pic's tonight for you - can you PM me a mobile number or email address so I can sms through to you.
Done, thanks!
I'll need to measure it up pretty well in person to be able to cut it to the correct shape.
Need to see if it's the right shape in terms of how my fuel system is set up and where my battery sits first. But will organise to borrow and get one to you once I know! :)
Looks Awesome Andrew! ^^^ Guessing this is the Soarer yeah?
Created some Clear Front Indicators for the SkyWagz cut from a Fluro Light cover as is the R31 way.
They're actually just attached ontop of the original orange lenses. (no need for orange bulbs) ;)
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
