Sprayed some black touch ups, and some gold pearl on the black bits. (mirrors, bumper lip)
Its black in the shade and gold bling in the sun. :happy:
My respirator filters were a bit old and didnt work too well. Nasty stuff, i dont feel too good. :sick:
So i decided rather than buy new filters everytime i want to spray something, ill make a constant air supply mask.
Easy, all i need is some small ducting, and i have everything else to make it.
Acrylic.
Gotta wait for it to cure.
If i knew how to set up the shed for 2 pack before i did it, maybe i would have gone 2 pack.
Not keen to ever strip it back to metal again, so any re-sprays will be acrylic.
If i ever get another one ill go 2 pack for sure.
Acrylic.
acrylic is HEAPS easier to paint with for a beginner. Much easier to fix issues. Can't wait to see the final product. How long now mik?
Breathing is highly overrated. :laugh:
Black / Goldish and Green looks Awesome in my mind, I'm sure it's going to end up better in reality.
Can't wait.
Tweaked the door latch striker plate dealies on the Wagz this arvo and got all 4 doors to sit flush when closed.
Much Better. :D
3 or 4 weeks
Maybe ill start rubbing it in 3 weeks and finish buffing by 4 weeks.
Dont want to wait at all but thats the way it goes.
And yeah, i got a couple of runs in the colour, they were easily fixed. No runs in the clear.
Being a commercial painter helps, using the gun is only a little different to a brush, a steady and precise action.
Thats actually black, only shines gold in the sun. Gold ghost pearl.
I couldnt do a large area with pearl, as its very tricky to make it even, only the pros can do a whole car with ghost pearl in the clear.
Want to buff it but i cant.... :/ Gotta wait.
Edited by D.I.Y. Mik
Still sitting on Jez's dyno at the moment.. Been a fairly long day. First issue was fuel pressure. Pump only had 10v. So we wired that straight to the battery on a relay to fix it. Still had issues. Pulled it out.. The whole mesh filter on the Bosch 040 was blocked with crap. We grabbed a walbro pump and threw it in to fix that. Huzzah fuel pressure!
Then came the misfire. Put splitfires in and fixed that.
No misfire but it still made no power. No variable can timing. We just found out the vct valve was faulty. Replaced that and variable timing is back! Will update later!
Edited by dontyellpl0x
Can't wait but gotta... Lovin' the colour combo. ;)
Will update later!
Good that you're ironing out some serious issues, unfortunate but it'll be worth it!
Interesting you didn't already have split fires.
or OEM coils like I got. :D
(you shoulda got some when I posted up the Ebay link months ago Chris as they have more than doubled in price now) :O
Today I washed the Micra, washed the Wagz, then went Nutz and Polished / Buffed it and gave it the mad Sprucing it so surely deserves including a good clean of the doorjambs and whitening the "NISSAN" on the mudflaps. :D
Will get pics in the light of day tomorrow.
Finally home!
Haha it's always the way. Interesting you didn't already have split fires. They are high on my list of mods.
Can't wait to see the final figure, make sure to get a dyno graph.
Yeah if there was something wrong with my oem coilpacks I would have upgraded. Jez said I wouldn't have known they were crap because they are normally fine for stock-12ish psi and anything above that they start to struggle just because they're getting old.
Yeah lots of small issues but worth it to have them fixed..
Haha if only!
Anyway after throwing in another vct valve it fixed that issue. Although now there was another restriction... It was making 212kw @ 14psi and only 220kw @ 18psi... Dropped the cat and hello 254kw! So we had to do a sneaky and break the catco cat. Anyway after Jez did some more tuning I ended up with 231kw @ 14psi and 245kw @ 18psi.
I'm a little disappointed that the extra 4psi didn't do a lot but Jez said whenever he tried to add any timing it was just detonating.. :( He said he's never seen such a sensitive engine haha..
Oh well, 245 is plenty to play with and I can turn it down to 14psi at the track to keep it safe. Feels pretty great so far! :woot::D
  • Like 2
Great Results Chris! Good on ya. :thumbsup:
Must be a huge difference in drivability and Wow.
Sounds like your engine has some mysteries like mine. :/
Did Jez say anything about acting as if higher compression than normal?
Mine made Trojan John & Jake think this.
Stoked for you. :woot:
Yeah it's different to drive alright! Great changes seem to come up so quickly haha
Yeah said he didn't really know why. Almost like it had 95 octane in it or something. But I've only ever used 98 and had just filled up with v power from a shell servo earlier that day. So yep.. it's a mystery :(
Time for a new exhaust.
What's on there now?
Generic 3" dump/front bellmouth to catco 3" "cat" ( ;) ) and then a hks high power cat back
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
