Good question Interested also as have pondered this previously
not sure if puff will run out on -7's before extra power potential from e85 realised
Edit: may have answer - same peak better response
Edited by Sinista32
Looking at around 335-340KW (I hope) with Much improved response.
Also it is just safer fuel. And for the $700 ontop of a haltech i couldn't not do a flex tune.
We will find out.
Current timeline:
Next week goes in for Haltech, 98 tune, replace some parts that are squeaking and new radiator hoses
Then:
Sell PFC, E-boost, Z32's
Buy HKS Air Flow Less adapters and the sensorz i will need
So in maybe a month? It will go to corn syrup
I bought my ecu specifically for its flex fuel ability. Tbh I don't think I'll ever use it. Once I go flex fuel it will pretty much never have e85 in it. I'd rather carry jerries and have all the powers :)
will work on that Rob
32/4 got a new mid muffler today, due to the cricket ball size hole in the original that appeared last week (25yrs old). Sounded tuff but I like the sound of silence. I still cant believe how lucky I was to grab this one !
34GTT is in getting all new suspension (coilovers etc), a full set of new shoes also. Car market dead so may as well keep and improve the beast. Not giving it away :angry:
Changing from RSR's to Falken Azenis 453's.
Found the RSR's not so good on RWD only skyline, noisy on the GTT, not so good on the street as they need warming up and found them quick wearing.
See how the new Falkens go.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
