Got some bits in the E-go Courier Post today. :) Gotta love Gumtree.
Extractors , Grill and ECU sent from Melbourne.
Supposedly the Extractors are Genuine SVD pipes, Grill is series1 or SSS? and ECU has apparently been Chipped to suit cam and port n polish.
Price was hard to resist. :D
Ordered surge tank+fittings for the cressida, some adjustable upper controls arms for the racecar and headstuds for the other gtr. Also ordered water and iac hoses for a patrol im doing a motor conversion on. Annnnnd im out of money again :/
Know your feel bro.
About to spend a solid amount @ Ultimate
Tried everything I could think of to get the broken exhaust stud out of the head but couldn't get it so I just slapped 7 new studs in, new gasket and put the SVD extractors on.
Old gasket was well past it's use by.
Recently made a shield for the pod filter too. TUPPERWARE!!! still has a label on it that says "popcorn" :laugh:
post-78856-0-43503800-1414324773_thumb.jpg post-78856-0-01958400-1414324868_thumb.jpg
also got a new pair of Driveshaft seals from Nissan.
Rang to order them as I was previously told by Nissan that they would have to be made in Japan and sent over. (3 - 4 weeks) and would cost $28.?? each.
Got them sent from W..A. in 2 days for $55 the pair. :D
Will get around to putting them in sometime...
attachicon.gifSkyHatch Post Extractors 1.JPG attachicon.gifSkyHatch Post Extractors 2.JPG
Wow that's probably the only Pod Box that has a lifetime warranty
Rob. Worthwhile finding a cover for the relays near the wiper bottle. Bit exposed.
Not sure if the fuseable links are meant to be covered or not.
The 31 is the same.
Not sure if the Tupperware warranty would apply as it's been cut. :/
The 31 is the same.
LIFE TIME WARRANTY.
You dropped it and it poped a hole in it....
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
