Fitted tow points and stickers required for the Snowy 1000
Washed it, Drove it, got it covered in bugs and then washed it again.
Filled up with E85 for next weekend
Where you in fyshwick today? Saw a white 260rs today.
Yeah man probably me. White, not too low, big rims - grey centres/polished hoops, fairly loud exhaust, no tint on the front windows and if you saw me at low speed Alcons on the front.
  • 3 weeks later...
Hooked up sat nav and mic. Also cleaned up all the dodgy wiring while I had the whole dash out. Last thing left is the reverse cam and finish off the double din surround fascia. Even put up a custom GTR wallpaper.
Edited by cpark
  • Like 1
Installed a new fuel pump in the cressida after the walbro bit the dust. Bit of a pain to do as you need to take the towbar off and pull the tank out.
Edited by k_d
  • 3 weeks later...
Adr approved Jeremy?
Who knows - cops not gonna like it regardless. Just like they're not going to like every other mod on my car. Also, given it's FRP it's not going to have the hazardous shatter like CF bonnets do. In short - no idea, but probably not.
Edited by RosieR34
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
