Hi all
Im hoping this is the correct place to ask this question
A m8 gave me the link to this site , hopeing i could maybe get some advice
I have a 88 skyline which untill recently has been going allright
But just last week , its been dying on me
I drive for say 10km - 10 mins roughly
then it starts spluttering and eventually just dies
It winds over fine , but wont start
If i leave it for say 30 mins it starts fine and goes for another 10 mins
At first i thought it was a blocked fuel filter and just using the fuel its got then dying , so i replaced the filter and its still doing it
Now im thinking its a temp prob
I took my airflow meter out and it still has the 3 wires in it , so i dont think its that
But maybe a sensor ??
Could it be that sensor thing that bolts in the the exhaust-extractors ??
Air filter is new also
I know i cant get an answer for my troubles
Just after a idea what it MIGHT be
I think i will have to take it into nissan i suppose
or if any one knows someone on the gold coast that has a clue
please any ideas would be great
Just aint loaded at the moment to be frowing money around on something that wont help
Thanks people
https://www.sau.com.au/forums/topic/41560-little-problem/
Its the Crank Angle Sensor (CAS). As it says, indicates the position of the crank which the engine uses to determine the timing. I think that is what it does anyhow.
One of the most common problems on the RB30E i think.
I used to have it in my old R31. Would be driving along, and just cutout completely. Would eventually start, but could take from 5 mins to 1 hour! Would happen when i would least want it to happen too. Anyhow, mechanic fixed and was fine till i sold it.
So yeah... 95% sure its that.
https://www.sau.com.au/forums/topic/41560-little-problem/#findComment-852406
I dont think it is the fuel pump because
when it stopped on me the other day , i pulled the hose off the fuel filter and it was full of fuel
Where abouts is Gavin Wood located rb25 ?? on the goldie ?
Predator that sound s like what mine is doing
Where abouts is that sensor ? You remember how much it cost to replace ??
Thanks guys
https://www.sau.com.au/forums/topic/41560-little-problem/#findComment-852920
Why would water temp senor stop the car? If that is bogus I'd imagine the car would still continue to run. I don't think it has an automatic cut-out for water temp?? And if buggered, your temp guage would be all over the place.
o2 sensor is another target, or the CAS as they do commonly fail. Sounds very similar to my old problem, and that was CAS related.
Anyhow, take it to gavin wood (or any other competent mechanic for that matter as its a local car).. check the QLD area and do a search for the address.
When you get it fixed, make sure you come back and post what the problem was for future reference :P
https://www.sau.com.au/forums/topic/41560-little-problem/#findComment-853821
predator, RB30s run dizzies, not CASs.
huskyboy, the engine will generally continue to run with a faulty / malfunctioniong sensor. I'd have some money on a faulty coil ignitor module in the distributor.
https://www.sau.com.au/forums/topic/41560-little-problem/#findComment-854321
Ok i rang Gavin Wood
straight up he said it was the crank angle sensor
Going to see if i can pick 1 up next few days
Damn dear suckas
repco has em for $339
Anyone know where i could get 1 cheaper ??
Would it be safe to buy 1 from a wreckers ??
He is to busy to do the work himself ( going rallying )
Is it a tricky thing to change ??
Thinking of getting me m8 to have a go
hes pretty cluey on cars
Can we do any major damage ??
LOL
https://www.sau.com.au/forums/topic/41560-little-problem/#findComment-856705
Ok bought the crank angle sensor
Got it pt in no probs , very simnple to do
Worked well for about a week now
Wasnt stopping but still didnt feel right
Now today i went for a drive from the goldie to Ballina
Hr and bit drive
Stupid thing shititself there
Same type prob started spluttering and eventually stopped
I went to a m8 for an hr or so then car went well
Left it there and hitched back to the goldie
Peice of shit
Going to have to take it into a mechanic next week
O well
https://www.sau.com.au/forums/topic/41560-little-problem/#findComment-874781
If there is no spark:
The System uses an LED crank angle sensor (CAS) within the distributor to generate a speed signal (360-degree for timing) and a position signal (120-degree signal) for the computer (ECU). The ECU then uses these 2 signals to generate a trigger to the power transistor (PT) bolted to the outside of the distributor. The PT uses this trigger to switch the -ve coil to ground to generate spark.
1 On top of the distributor is a 4 pin harness plug - this is the crank angle sensor. With this plug removed test the voltage on each pin of the female harness plug against ground (engine earth/battery -ve) with the ignition on (KOEO).
2 Should have 12v (battery volts from the EFI relay), earth (Ov), and on the remaining 2 pins - 5v on each (from ECU).
3 Ensure the distributor shaft is turning during cranking - cam belt.
4 With the engine cranking these 2 wires which had 5v on each are the important signals you are after - expect approx. 2.3v on one and 0.3v on the other. If the CAS has failed expect close to 5v OR close to 0.0v on one or both. If the signals are BOTH within 20% of specs., then
5 Check the signal from the ECU to the PT (fawn wire onto PT). If ECU is generating the correct signal expect approx. 0.4v. If a greater voltage, then you have an earth problem. If 0.0v then the ECU is not outputting the signal - ECU failed. If correct signal but still no spark then the PT has failed to switch the coil (rare) or the coil has failed (common).
6 To check the PT is switching the coil, use a normal test light from the +ve battery to the -ve coil (brown/red at PT). Your light should illuminate with KOF (ignition key off), and when the coil is switched to ground through the PT during cranking. If your test light flashes during cranking then PT is doing its job so coil has failed. If no flashing then PT has failed. Or if test light constantly lit, then PT has failed.
Another common problem with the 3-litre Nissan engine is where the idle deteriorates to the point where it will not even run. Before that happens there is an initial loss of power, which just gets worse. A prime cause of this is the Air Mass Meter drifting beyond specifications - check the load pin (3rd in from back of engine - white wire) against an earth should have KOEO no less than 1.26v (excessive lean) and no more 1.32v (rich). If this load setting base is out, you won't be able to adjust the idle mixture (1st pin in from front of AMM) factory lean at 3.6v to richer say 2.0v to a satisfactory mixture - AMM will need replacing
MEGA
https://www.sau.com.au/forums/topic/41560-little-problem/#findComment-874858
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
    • Yes they do. For some maybe. But for those used the most by abusers, ie Skylines, the numbers are known. The stock eyebrow height for R32/3 Skylines is about 365/375mm or thereabouts. The minimum such heights are recorded in adjacent columns in the database.
