Special offer from UAS
Polished radiator air guides for R33 GTS-T.
Normally $75.00
Group buy price $40.00
Offer available until June 30th or while stocks last.
Image below shows the air guide fitted to a series 1 GTS-T
Call us on (02) 9634 8000 or send us a fax (02) 9634 8888 to order.
https://www.sau.com.au/forums/topic/41563-alloy-radiator-air-guides-r33-gts-t/
  • Replies 79
Is it possible to get them where it covers the entire front section? (ie; covers over behind the headlights etc all as 1 piece rather than just the radiator part?). I seen a car at the UAS Wakefield day that had 1 and it made everything look very neat and tidy.
Benm: I had a look at these yesterday - unfortunately they are only available as pictured
dAVE: They are quite light - thin but strong enough IMHO
meshmesh: Im going to speak to UAS about the series 3 lip group deal.
nice try Blitz, but that comment did NOT answer my question.
They don't need to be strong as no load on them. We had thicker ones but not as easy to fit and no need for thicker.
Re R34 we don't have YET. If someone wants to come to our shop with one to be a test car we could trial fit and see.
We have air guides for R33 GTR which is a little different and not part of this group buy sorry.
Cusco make air guides for lots of cars and on their site they quote up to 20% more air flow through the radiator by blocking easier path for air to go rather than through the radiator core. It also looks good and gives a place to put stickers if you want.
Hi Zed,
Are you going to do a group deal with the Series 3 GTR Lips? Please.
totally different, even R34 will have 2 different hood panel due to the sport and normal style front bar.
and GTR is different to Gtt.
Here's a pic of mine I just installed:
http://www.nitroware.net/~tony/r33panel.jpg
I do note that my bonnet is a bit harder to close for some reason.
Like an idiot I forced it and it did pop shut and when it opened there was no marks.
T.
Hey, I'm in Beecroft too. Never seen any Skylines in this area. You wanna meet up and see my cool panel :D
T.
Go to our site and go to freight section and also orders section. CC is fine as long as it is not your girlfriends.
http://gtr.com.au/order_form.htm
Yes they fit series II although fit Series I better.
Jimbo yours is fitted now.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
