ill confirm it for you, im 100% on this, i looked into it a fair bit. it has to be completely enclosed to avoid a fire hazard because the pod filter is made of paper after all. to avoid the paper catching on fire it needs to be completely enclosed.
i really dont get the point of those half assed covers on justjap and ebay that only cover the top of it.
so does this mean if you have the stock air setup with a metal intake pipe, the induction sound will remain?
dammit. ok , so any links to fully enclosed boxes for pods as I want to retain the bov sound
thing is, if you do get a legal fully enclosed pod filter cover, there probably wont be any sound, similarly to the stock airbox.
ahh im going crazy without the sound, contemplating pulling one of the pipes off the BOV valve off, to get a bit of a flutter :P
Hmm... well next thing is...how knowledgeable is the average cop on the legality of a fully enclosed box?
If they just see a cover over it (that they cant remove at the time) are they likely to look beneath it or even know that its supposed to legally be fully enclosed?
Not all states have exposed pods as illegal. Qld doesn't (just has to be secured with a bracket). So enclosures like the just jap one work well as heat Shields, which is the point of them. A pod in a fully enclosed box often won't flow any better than a decent panel filter in the stock box.
Pods don't need to be boxed in the ACT either, just secured.
Pods in the engine bay are sucking hot/warm air unless shielded.
Noisey Bovs are noisey due to turbulence, therefore not moving the air as efficiently as they could.
Personally, I would rather a stock box knowing the air is as cool as it can be and a plumb back Bov that's quiet is doing it's job well.
Function over fashion.
The stock bov makes a fair bit of noise when it isn't muffled by the airbox. Pull the snorkel off the stock box and you will hear the stock bov a bit. It isn't louder because it is more turbulent, simply less muffled. The same goes with having the stock bov and a pod. I made an alloy heatshield for my pod and all the intake and bov noises got louder because it acted like an echo chamber.
As for air temp, a decent intercooler will negate the higher air temp to a certain extent. And then there is the argument of air temp vs air volume. If you are at a power level where the airbox is becoming a restriction, an exposed pod will work better than an airbox. Obviously the colder the air, the better, but it has to be within reason.
well with laws and performance partially aside. is there any way to get the best of both worlds. which is having sound as well as having a stock looking air system. removing the snorkle alone didn't increase the sound noticeably.
I had no way to fit a stock air box on my set up... So pods were the only option. I will be getting these boxed, More so a cover for the top & sides and a Cold air intake feeding from the pods from the bottom of the box
so , have we come to the conclusion that as long as you have a heatshiled cover of some time , the majority of cops will not defect you?
Also , there is no way to keep the bov sound while having a pod legally ( it being fully enclosed) ?
Just move to QLD or ACT=Profit.
lol , yes pack up and move purely for the bov sound...
just get the cover man..
check my other thread
as long as your car isnt to loud , its isnt ridiculously low and you arnt driving like a total d*ck , you should be ok 99% of the time
at the end of the day you drive a skyline and if a HWP wants to defect you , he will.
okay, so i've finally gone crazy without hearing my turbo for way too long.
I've decided to make a box to hold the pod filter in, there are heaps of images and threads on this everywhere, but i've got one main question.
if i did make a box to hold the pod filter in, would this box muffle most of the blow off sound that came from the pod filter?
and what material/metal is best to allow most of the sound to be heard?
wish i could just make one outta aluminium foil :P.
anyone have any recomendations on types of material to use, e.g which metal? something thats not too hard to get, not too expensive, yet is thin?
    • Pressure when IDLING, is meant to be 51PSi... So that amperage value needs to go up a fair chunk... I'd personally be factoring for more like 12amp at least on those runs, and at that point you need to hope the already there wiring doesn't drop you a volt or two, as that's a lot of fuel pressure flow drop off from 13.5 to 12V! Taking idle pressure of 51psi, means the pump will be drawing a MINIMUM of 9amps all the time based on your reading of the graph (3bar base, then allowing an extra 0.5bar for boost = roughly 51psi)
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
