Up for sale is one of my dailys I don't get to drive often enough.
It's a sweet ride too.
Price $7800 obo
1998 Honda Prelude VTiR - 213,000kms
DOHC VTEC 2.2 Litre
3 months rego
Full Leather interior and Sunroof
4spd Sports Auto - (you can change gears if you want to as well)
Second Canberra Owner from new
Always serviced and no expense spared.
Seems alot of K's but come see it and drive it. It is like new.
No smoke and no "little issues".
It has a small stone chip here and there and a scratch on the rear bumper left side.
The drivers side seat does have stiching tear down the side. Easily repaired
In the last 6 months
It's had it's second 100k service with the lot - including Harmonic balancer, timing belt, water pump etc..($2200)
Transmission was sent away last month for a full recondition including gear sets and torque convertor ($3700)
Full service with engine flush and fluids replaced in the last few months; and
today I had the radiator and thermostat replaced. ($565)
Loads of pics and more to be added over the next few days.
https://www.sau.com.au/forums/topic/415824-honda-prelude-vtir-1998/
If the Prelly doesn't sell I will take offers around $14k for my other daily, the Tokyo Taxi (R34 GTT).
34 GTT is a 2001 RB25 NEO with 120,000kms
Both cars are stock except for a K&N filter in the VTiR and a Pod with Nismo zorst on the 34 GTT
I dont mind which one goes but one of them has to. You just cant drive 3 cars.
Im trying to convince a mate to pick up your 34 as a tree fell on his car on christmas eve from that storm we had...
Thanks Mate, cleaning it after home made BLT lunch and will give it a petticure too :wub:
Edit: better let him know it's the sports tiptronic and not just manual.
  • 3 weeks later...
Karn ya tight Kunce buy my Honda Prelude VTiR for your daily, your mistress or your teenage bratz. (persuasive hey :) )
$6500 for this week. It has 3 months rego and you wont be dissapointed. !!
Full Leather interior, Sunroof, Sports 4 speed trans (and it's a new transmission), new radiator, harmonic balancer, major services etc...
So damn Klean and so Kool :cool: to be seen in
145 kws of Jizz in your undies/nickers POWA :w00t: (oh and it's stock - lol)
and see the angel eye's of this babe :wub:
The :kiss: will leak like a busted fridge if you buy this for her
Strueth - It's like bloody new folks
I'll race you for your pink slips in the beauty!
Don't ever let a great opportunity go bye bye's !!!
It's another prestige proven performer from S!N Performance Vehicles (Pty Ltd)
  • 3 weeks later...
    • Hi. This is just my curiosity because iam sure the tuner figure something out...but either way i want to ask. The "problem" is that the Nistune ECU (Stagea FW and RB25DET NEO from Stagea) sees many times the speed than the speedo does(he says the speedo show 120 km/h - correct speed and the ECU shows like 510km/h ) I told him that this car/tranny getting speed from rear diff. If iam not mistaken the RB25DET NEO "need" to see tranny speed sensor? (my tranny has the plug for it). So couple of "question" If he connects/wire the speed sensor to the tranny...are the signals gonna intervene and if...what if he disconnects the rear diff one and the speedo stops working? Or the "new" sensor from the tranny "take over" and will not going need the one from diff? As i said i know he figure/get that done...iam just curious to know what are the solutions 🙂
    • Your IACV is set to idle too low. You need to adjust it via the screw Duncan mentioned. From memory it should be 650rpm with the valve electrics unplugged. What is it trying to idle at with the IACV plugged in?
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
