So i have rescently purchased a r33 gts-t s2 1996, it ran fine for a few days until now when i took it for a drive and drives okay, but when i put my foot down and accelerate and hit boost it just gets rough, the whole car shakes, my foot on the acceleration shakes, it feels like the power just dies out.. im no big mechanic guru so i cant really get my head around this, any help will be appreciated! cheers
https://www.sau.com.au/forums/topic/416147-not-hitting-boost-like-it-should-be/
  • Replies 48
You would be well advised to provide more details. Such as rpm where the bad things start, max revs you can get, max boost it sees, any noises, whether the shaking feels like something mechanical is out of balance or it is a power on-off-on-off-on-off type thing. etc.
First check afm. Take air filter out clean it with some throttle body cleaner and clean the afm the same way. Do this before you do anything else because its the most common issue and easiest fix.
how would spraying the air filter with throttle body cleaner be a good thing? wouldnt you just replace it if standard and if a pod use some compressed air to blow in reverse direction?
I think mental shorthand became the typed word. Expand his instruction to something like "remove the air filter and spray the AFM with throttlebody cleaner".
Of course, that's not smart anyway. As many AFMs have been damaged that way as have been fixed. I would use CO contract cleaner spray rather than carby cleaner.....and be very careful about how I sprayed it.
Sorry should have elaborated. Take off you air filter. If it is disposable get a new one. If it is reusable tap it gently to remove the debris. Then use a soft brush or air compressor to remove the rest of the impurities. Then once you inspect it and are happy with the result remove the soot type impurities with throttle body cleaner or contact cleaner. For the afm, remove it and brush over the mesh with a very soft brush making sure you are holding it so the debris fall away from the centre element. Once satisfied with the result of both sides get some contact cleaner and spray from a distance onto the element to clean it. You can use throttle body cleaner as I have never had an issue. Up to you. If you have contact cleaner also apply to the afm plug. Hope this helps
okay right, first off i should say the bad things started happening around 3000rpm to 4000rpm and beyond that i did not continue accelerating since things got messy, i have a dodgy boost gauge that came with the car and seems to function but id rather not go with it for a correct pressure reading. when i bought the car i did see that the podfilter bracket that holds it, is broken and now its just dangling on the shell, and also the AFM bracket is snapped, so there is not a full seal from filter to AFM to piping, could this be the problem? if so, new pod filter and AFM?
You mean the outer shell of the AFM is broken? Or the intake pipe is otherwise compromised? This is a serious problem but it might not be THE problem.
How much boost?
What is the ECU ?
Check for any air leaks especially between:
1 - AFM and turbo
2 - Turbo and throttle body (BOV connection, intercooler pipe connections, etc).
I took some photos so i can explain it better:
http://i1272.photobucket.com/albums/y396/Adrian701/IMG_0134_zps7bb973ee.jpg
In this one i found the circled hose being off, and im uncertain what the black box it came from is..
http://i1272.photobucket.com/albums/y396/Adrian701/IMG_0137_zpsea39cd84.jpg
Where im pointing on this, there is a mixture of water and something else overflowing just to the rim of that larger hose, but the hose loops around to that pulley from the left of my hand (water pump?)
http://i1272.photobucket.com/albums/y396/Adrian701/IMG_0133_zpsc99e6ba4.jpg
And in this one, you can see the AFM bracket mount is snapped (previous owner tried to super glue it -.-) the right hand side bolt on the pod filter just pulls out so its not vulcanized in the rubber anymore and the left one is not far from it too, and that F*** off bracket is completely been made wrong side it dosent even bolt on, thats no problem since i can make a new one myself
i have also tightened all my head cover bolts, since they all seem to have atleast another turn to them.. the furtherest ones so closest to the windscreen seem like they have been leaking over the time very slowly
the ECU is stock im pretty certain, and uncertain of the boost :/ i ran my fingers across all the piping and i cant see or feel for any damage/leaks
thanks for all the help again!
http://i1272.photobu...zps7bb973ee.jpg
http://i1272.photobu...zpsea39cd84.jpg
http://i1272.photobu...zpsc99e6ba4.jpg
wonder if im seeing it wrong but does the top of the boost control device have no hoses? or am i looking at somthing else, pretty sure mine has some vacumn hoses connected to that, second picture where the fingers are, under powersterring reserviour
Edited by SliverS2
yeah i was wondering what that was, so its clearly missing the 2 hoses but i couldnt find the where they would plug in, any thoughts? thanks
from memory, you should have one from the compressor cover, on the side, that will plug in the the solnoid and then the actuator one will also plug in , can you locate them?
im afraid not, could this be related to my initial problem, car getting rough when you put your foot down/ loss of power?
ive listened carefully to the idle as well, and its a bit rough too..
previous owner claimed that the coilpacks are new, so that would be safe to rule out?
Edited by AdrianGTT
It sounds to me like its atleast contributing if not the solution, you have a vacumn leak and you have no boost control so its overboosting by sound of it and hitting massive RnR, connect the lines back up properly and see what happens
from my experience with my own coilpacks, they didnt affect idle they made the engine start backfiring a bit violently at about 4000rpm on high boost with around 200kw , check your plugs and hose clamps too
Edited by SliverS2
thats my problem, im not sure what lines go where, maybe a picture of your setup will help? i searched some links on google and i cant find anything similar
mines an external gate setup so probably wouldnt help, just connect the compressor cover one to the bottem and then from the solnoid connect a line to the actuator and see what happens, your bascially just feeding the pressure to the actuator from the compressor outlet so probably work either way, but expose the actuator under the big flat cover so you can see if it is connected to somewhere or not.. could be just clutching at straws here,
hope that helps
someone chime in to correct if im wrong...
Edited by SliverS2
pictures would help a bunch or a link with something since im not big on the technical words, im tempted to just take the car to my local tuner but then again i dont want to do that just to connect some lines for me, thanks again!
ive also found a nipple with a bolt in it under the purple pipe.. dodgy
http://i1272.photobu...zps3fad0b48.jpg
http://i1272.photobu...zpsd73d5f66.jpg - there is this black thing that im holding as well to which i have no idea what it is either.
could you take my photo and draw a few arrows on paint with what hose goes where, or what hoses i need to get? that would be great! cheers again for everything mate
Edited by AdrianGTT
You can see in the same picture he has a boost controller.
Manuel one that is black.
So no his boost controller does not need hoses
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
