So for the last few months i've been filling up at around 300km. I have an Injen CAI and no other engine mods.
I just filled up then and my needle was just above empty (i do realise that the needle is a little incorrect)
I filled up the tank today at 287KM and my car took 41L of fuel, i know the tank holds 80L but i have never driven the car to completely empty, in fact i don't think i've even done over 400km to the tank.. I feel so stupid because i've been filling up way before necessary, with the driving i do i should theoretically be getting close to 500KM to a tank.
Facepalm.
https://www.sau.com.au/forums/topic/416439-whats-your-average-km-to-a-tank/
I usually get around 600km before filling which is usually just after the fuel light comes on. I usually manage 11.5L/100km in winter. And about 12.0L/100km in summer (heavy AC use in summer). Which gives me a theoretical range of 660-700km per tank.
All light city driving.
6MT sedan. With shell 95RON fuel.
Edited by sonicii
I usually fill at 1/4 left by which point there's 400km on the clock. Was avg 12l/100km. No ac, start stop traffic though. Stock as a rock.
After changing the diff fluid, this seems to be getting better. Now looks like closer to 10l/100km but we've been doing a lot of motorway Kim's during this season.
Mines stock and I got 730km driving from Sydney. Around town I get around 550 ish
That's impressive!
aha I don't even trust the needle anymore, i just watch how many km's i've done and where i've been driving/how i've been driving then fill up when i deem approprite. But this time i've going to let it run to 500 then refill and see how close to empty i am then.
I have only done 1 highway trip in mine. Townsville - Yeppoon and return.
1 tank each way, about 740km. Low fuel light had just come on when I arrived in Yeppoon. After filling in Yeppoon, i still had 1/4 of a tank left when arriving in Townsville.
From memory, I averaged about 7.8L/100km overall.
After reflashing with the Uprev software, my first full fill up on 98 till now was 790kms. Not even kidding. Will be interesting to see if this can happen again... :S
Did you drive to Sydney?
Cruise control 95kmh behind a road train?
James sometimes an automatic with cruise control can actually be worse on fuel than a manual because of the constant gear changes. At least i know for a fact this is the case for the mid 2000 model Prado's.
Good question.. under want conditions did you get 790km from 1 tank? if it was highway KM, then this is about normal.. if it was city driving then it is very impressive.
I'm guessing that must be highway km unless he's driving a little 1.5L v4. Max i've gotten out of mine for highway km is about 700 and that's with a little bit of enthusiastic driving.
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
