So for the last few months i've been filling up at around 300km. I have an Injen CAI and no other engine mods.
I just filled up then and my needle was just above empty (i do realise that the needle is a little incorrect)
I filled up the tank today at 287KM and my car took 41L of fuel, i know the tank holds 80L but i have never driven the car to completely empty, in fact i don't think i've even done over 400km to the tank.. I feel so stupid because i've been filling up way before necessary, with the driving i do i should theoretically be getting close to 500KM to a tank.
Facepalm.
https://www.sau.com.au/forums/topic/416439-whats-your-average-km-to-a-tank/
I usually get around 600km before filling which is usually just after the fuel light comes on. I usually manage 11.5L/100km in winter. And about 12.0L/100km in summer (heavy AC use in summer). Which gives me a theoretical range of 660-700km per tank.
All light city driving.
6MT sedan. With shell 95RON fuel.
Edited by sonicii
I usually fill at 1/4 left by which point there's 400km on the clock. Was avg 12l/100km. No ac, start stop traffic though. Stock as a rock.
After changing the diff fluid, this seems to be getting better. Now looks like closer to 10l/100km but we've been doing a lot of motorway Kim's during this season.
Mines stock and I got 730km driving from Sydney. Around town I get around 550 ish
That's impressive!
aha I don't even trust the needle anymore, i just watch how many km's i've done and where i've been driving/how i've been driving then fill up when i deem approprite. But this time i've going to let it run to 500 then refill and see how close to empty i am then.
I have only done 1 highway trip in mine. Townsville - Yeppoon and return.
1 tank each way, about 740km. Low fuel light had just come on when I arrived in Yeppoon. After filling in Yeppoon, i still had 1/4 of a tank left when arriving in Townsville.
From memory, I averaged about 7.8L/100km overall.
After reflashing with the Uprev software, my first full fill up on 98 till now was 790kms. Not even kidding. Will be interesting to see if this can happen again... :S
Did you drive to Sydney?
Cruise control 95kmh behind a road train?
James sometimes an automatic with cruise control can actually be worse on fuel than a manual because of the constant gear changes. At least i know for a fact this is the case for the mid 2000 model Prado's.
Good question.. under want conditions did you get 790km from 1 tank? if it was highway KM, then this is about normal.. if it was city driving then it is very impressive.
I'm guessing that must be highway km unless he's driving a little 1.5L v4. Max i've gotten out of mine for highway km is about 700 and that's with a little bit of enthusiastic driving.
    • Here is a recipe. Sonic blocks till you get one that has a good enough bore. Get a torque plate and block brace, use your choice of fasteners (arp ect) bolt the thing together empty, half fill it and let it cure. Release it when it has, go to a REPUTABLE RB Builder and get the thing line bored/honed and cylinder honed to size, then wash. Once its all clean and dandy, wash and blow it out again. Then again.  Assemble said engine to your desired clearances with oil control mods, gasket to suit desired CR/Squish ect. Attach your extended sump with proper trap door oil baffles and head drain plumbed to sump with a SUMP BREATHER SYSTEM. Build your front diff with a decent LSD, rebuild your transfer case with a few extra plates, more than likely replace your tailshaft centre bearing and tighten up the rear diff. Tune to minimise excessive midrange cylinder pressure (timing unless you like to split bores and rebuild engines) Enjoy your engine, but hate the fact you are now destroying engine mounts, gearboxes, gearbox mounts, diff output flanges and driveshafts, diff mounts, tailshafts and front CV's.   Disclaimer.... Ive never done any of the aforementioned stuff.......
    • 440s will support well over 400HP on petrol, which is a decent place to be for an RB20. 230+rwkW. Will be a safer bet for idle/low load. 550s would be nice for the extra headroom. I've made the same decision with mine (Neo25). 1000s are probably too big for the Nistuned ECU, so I have some smaller ones.
    • Appreciate everything guys. I did go ahead and get an alignment... most of my complains are solved. Car is not perfect, but it's good enough. If I notice uneven tire wear or anything I'll just take everything back to stock.  Thanks again!
    • They still have not shipped the 550cc injectors as they weren't in stock, so in theory I could ask to get the 440cc ones instead, if those work better in my scenario. They're the same price so really shouldn't be an issue. Unfortunately I am not so knowledgeable in most parts of tuning so I wasn't sure what's best to choose between the two. 440cc ones are the lowest they have (not in stock, but available to buy nonetheless).
