  • Replies 53
My understanding for ACT rules regarding FMIC:
If your vehicle was fitting with an intercooler mounted anywhere on the front of the car (side-mount counts) then you're perfectly within the rules to change to a proper front-mount intercooler provided that you didn't need to modify the chassis (cutting hole for return pipe) or reo bar in any way. Obviously it has to be mounted properly. Dickson had no problems with my front mount, and I don't believe it was noted on the engineer's report (well, at least not in the same way my turbo/suspension etc were).
https://www.sau.com.au/forums/topic/416453-defected/page/2/#findComment-6686634
Nope, only if it's newer than 10 years old. Just went through the process with my daily driver.
If its only there for a history check wouldn't they just need the vin etc not to look at everything on the car though?
Because I thought you only did the history check etc after you got a rwc for interstate cars?
I'm thoroughly confused on it!
https://www.sau.com.au/forums/topic/416453-defected/page/2/#findComment-6686684
No idea! I'm just sayin to transfer my Beema from NSW rego to ACT rego all I had to do was go get it inspected at any authorised workshop (which I did) then took the paperwork to dickson with the old plates. Signed some shit, got new plates and was done.
Was very easy. It's nice to have one car that is straight forward!
https://www.sau.com.au/forums/topic/416453-defected/page/2/#findComment-6686911
All I had to do for the GTR was get it inspected at Ultimate Tunes then go to Woden hand the old plates in and get the new. Maybe because the car was older than 10 years?
I have to do my 2004 XT Forester in February so will be interested to see what I have to do for that.
https://www.sau.com.au/forums/topic/416453-defected/page/2/#findComment-6686948
Yeh for some reason you only need the history check if it's less than 10 yrs old.
I don't get why they need you to go to Dickson for it though...
The idea behind the ID check is that its supposed to check that the car hasnt been rebirthed or anything
https://www.sau.com.au/forums/topic/416453-defected/page/2/#findComment-6688390
Well that's a kick in the grundle then isn't it.
Is there anyway to avoid the Dickson history check with a newer 2nd hand car? Like getting documents which show it's history from car dealer and previous owners etc or something along those lines?
Why must they be such douchebags...
https://www.sau.com.au/forums/topic/416453-defected/page/2/#findComment-6689019
before putting all this fear into the masses.
They actually do their job, just sometimes it seems over zelous on the imports and modified vehicles.
My main gripe is that alot of our cars are ALOT safer than most shitters on the road. Yet we appear to be the centre of their target (ing).
https://www.sau.com.au/forums/topic/416453-defected/page/2/#findComment-6689158
Ahh, but they also have a habit of choosing when and when not to 'do their job' by selectively ignoring certain things....as well as not even knowing their own tech standards they should be following half the time. lol
https://www.sau.com.au/forums/topic/416453-defected/page/2/#findComment-6689193
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
