Its been a while and the old 210 has been a bit spluttery but its finally time for some real work!
the l24 has been leaking exhaust gaskets, sump gaskets, rear main seal and many other places... so its been pulled down for a bit of maintenance..
https://docs.google.com/open?id=0B9IBf0LCEVgMUkpuREw3M3pBbU0
so ive pulled the water pump off all manifolds gearbox, sump, dizzy, flywheel, rocker cover... is there anything else that i should check/clean/test/replace?
im considering building the l26 i have in bits and putting that in... any ideas would be appreciated..
https://www.sau.com.au/forums/topic/416518-a-short-update/
Depends on what you're chasing, a freshened L26 is a good idea.
Making sure with either engine you change your rings pending condition.
Cause i didn't when i did my headgasket and it now smokes like the batmobile
https://www.sau.com.au/forums/topic/416518-a-short-update/#findComment-6687150
If bottom end is in good order, and you've still got factory bore/hone marks within cylinders (ie not glazed) plus good compression, you should be ok for a while. Otherwise, with what you've done, I'd also replace the stem seals for sure. If you don't have the head off, get a shop to do it, or you can try yourself with a compressor & spark plug adaptor.
What head you running,, early type? I'm not sure on valve seat specs for C210. If early type, get a shop to replace valve seats or, get an R30 head, or even just buy yourself a 'valve saver' lube kit, fit it in line btwn carb & distributor, it'll save the head from dramas.
https://www.sau.com.au/forums/topic/416518-a-short-update/#findComment-6692995
its an E30 head on the l24... running LPG but its only done 50,000kms on LPG and about 100,000kmd on petrol.. had the sump off and it appears all the hone marks are still the from what little i can see/feel
whats a rb 30 head change involve? havent heard of that one before... would a rb 25 head work then for the twin cam...
Cheers
https://www.sau.com.au/forums/topic/416518-a-short-update/#findComment-6698757
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
