Hi All,
I have a R33 GTST and i am looking to buy a bigger Turbo but need help decidiny what to get, i dont really want anything that will need a external wastegate or new injectors.
the mods i have r
3.5" Exhaust
Hybrid FMIC
Apexi Power FC
Air Filter
Fuel Cut Defender
i was looking at the Hybrid T3/T4, but would really love something bigger that wont max out my injectors.
if you can let me know what turbo, specs, price range and amount of boost i can run with the above mods, that would be great.
thanks guys
Craig
https://www.sau.com.au/forums/topic/41652-help-what-turbo-should-i-buy/
yea thats all god guys and id love to spend that much and i could but, i have been told if i put a T04 turbo on my injectors will MAX out at around 10 PSI, and i dont really want to get injectors, im after something like a T04 , nothing too big, or even a ball beariong T03/04.
i could spend more but i just want to spend a little for now, while i have heaps of other things on,
Would a T04 max out my injectors? i would like to run about 14 - 20 PSI ( in that range)
I was told I can put a 2535 without upgrading my injectors, someone here in the forum has done it and his injector duty is only about 85-90% from max. Not sure how much boost he runs (maybe 0.9 bar). But even a small 2535 has boost efficiency above 1 bar (14psi). Can't remember how much, perhaps 1.2 to 1.5bar.
Just get a good fuel pump, like a GTR one (cheap 2nd hand) or a new Bosch 040 if you can't be bothered to get 2nd hand parts.
I know you dont want to hear it, but even getting everything 2nd hand will come to more than $1,300. doing the turbo thing isnt cheap! when i did mine, like you i didnt want to spend much at all, but it just isnt possible. getting a small turbo (2530) needed the fuel pump and regulator to be changed, not to mention small things we all like to forget when performing this upgrade, like oil and water fittings for the turbo, intercooler pipe modification exhaust/dump mods, the list goes on.
i thought after i spent $1500 on my turbo that there wouldnt be much more to spend on the transplant - $500 in fittings and line - $300 for a reg - $400 for a pump $200 cooler pipes. it ends up getting pricey regardless of whether you go new or 2nd hand.
Maybe put the money away and save a little more so you can do it right the first time, it gets even more expensive when you have further plans down the track...
good luck with what ever decision you make!
I'm a bit confused :D
Do you just want a bigger turbo cause it's bigger, or do you want more power so your car's quicker?
Have you thought about what power goal your aiming for?
Once you workout what power you want, then you can look at what you need to do to get you there. Remeber that power isn't everything, sometimes the money is better spent on a good alignment and good tyres etc...
Just something to think about cause I think $1300 is going to fall short for a turbo upgrade.
J
BTW: A TO4 turbo won't be a bolt up turbo, so your looking at a different exhaust manifold and dump pipe, not to mention different oil and water lines :P
robos - no, no and yes
the only thing that bolt straight up are the manifold flange, exaust and intake pipe.
i had to get fittings for all water pipes, oil lines and intercooler pipe. so it ends up costing a fair bit
eav00l: Quote "if theree are anymore suggestions please let me know" Bendigo bank have some good interest rates if you deposit over $1000 get it in there and start saving :P
When I bought my car it came with a CGC stage2 450HP upgrade allready done to it, it's probly your best option as everything will bolt straight back up perfectly. I'm not exactly sure if my car has standard injectors or fuel pump and I cant check as it's getting work done to it and not in my garage, but I've seen the turbo pump out 16 pounds with no problems at all and comes on boost strong at 3,400 rpm and really throws you back, enough to spin the wheels in the first few gears without droping the clutch.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
