2001 NM35 Nissan Stagea RX FOUR 250t
133,000kms
Nismo ECU
Nismo Instrument Cluster
Nismo LMX5 Wheels (slight gutter rash, new centre caps)
BC BR Coilovers
Freeway Dolphin Swaybars
Polyurethane Castor Arms Bushes
HDi Intercooler
Nissan Factory Sports Muffler
Blitz External BOV
Transmission Valve Body Upgrade
Project MU Brake Pads and RDA Slotted Rotors
ARX LSD Differential - No HICAS
V35 Manual Radiator with Aftermarket Cap
External Transmission Cooler
Greddy Informeter Touch- http://www.greddy.co...ics/informeter/
Clarion Head Unit with iPod Interface and BlueTooth Connectivity
WD Media Player with USB Interface
Steering Wheel Audio Controls (needs Clarion interface to control the Head Unit fitted)
Factory Reverse Camera
ST49EA Number Plates (will be sold with the car)
Aftermarket (brand unknown) grill
Aftermarket boot wing/lip
Nismo Badging Front and Rear
Nismo Stripes
VIN: 6U90000NM35303052
Engine: VQ25151346A
Plate: ST49EA
Rego Exp: 02/10/2013
Asking $16,000
Also have separately (not fitted to the car):
- Navy Velour Front/Back Seats (dusty from storage, but in great condition otherwise)
- Apexi N1 Exhaust
- Aftermarket Dump Pipe
- Aftermarket Front Pipe
Front tyres are almost brand new, full wheel alignment performed. Car regularly serviced with only the best.
Photos are also available here: http://forum.silvian...pic.php?t=35360
Sunroof?
No the car doesn't have a sunroof.
Can't say I am a fan myself and particularly in the Stagea's if your average or above height you can't fit in with a helmet easily with the sunroof.
What are the advantages of the Nismo ECU?
Its similar to that of having an aftermarket ECU, however this is the Nismo (thus Nissan tuned) version. Better tuned for performance over the stock ECU.
Massive advantage. More throttle allowed below 3000rpm in 1st (where the stock ECU limits to 30% max throttle) plus better performance perameters.
Last on when found sold for $1850.
Car has been SOLD.
Still have the following various spare parts for sale:
- Velour Seats - Front - $100 (great condition, a little dusty from storage)
- Velour Seats - Back - $50 (great condition, a little dusty from storage)
- Apexi N1 exhaust (cat back) - $400 (or take the Cannon, Dump & Front pipe for $900 all up)
- Scotty's Dump -$300
- Jap Front Pipe - $400
- Stock ECU with mounting bracket - $100
Take the lot for $1000 :)
Will try and take some photos this weekend... exhaust parts are in A+ condition, most haven't been on a car yet!
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
