Sup peeps
I'm a newbie to the skyline thingy so bear with me...
i've got a rare DR30 Skyline Turbo and I was wondering if it's possible to install a BOV into it.
Friends tell me that you can fit a BOV into any turbo car, but I can't help thinking that my car is too old to install such a thing...
Any advice's appreciated...
https://www.sau.com.au/forums/topic/41657-bov-in-a-dr30/
Man I am SO glad to know that people actually like a DR30...
people give me crap about how its too old... i have a lot of pride in it though. I think the DR30s are better than the R31s... Absolutely no offence to owners of R31s...
again, will post pics soon, just doing my stupid uni assignments X(
Skyline Forum seems like one big happy family! nice to hear! :D:D:D
https://www.sau.com.au/forums/topic/41657-bov-in-a-dr30/#findComment-857417
