So yesterday I finally put in my new head unit that I bought a few months back. The head unit itself is a Clarion CZ702A, which itself reviewed very well by MEA (http://www.mobileele...02a_cd_tuner-1/) and I used all Aerpro harnesses etc to get it installed without fuss. I also got the harness in readiness for steering wheel controls.
Essentially the harness gets you from Nissan to ISO format, then you go from ISO plugs to whatever your deck is.
Aerpro Harnesses used as follows:
- Clarion to ISO Harness 15 Pin (APP8CLA) - Clarion to ISO format
- Clarion Adaptor Cable Suits Control Harness A (APCLAA) - Clarion SWC connection
- Control A For Nissan 350Z 03, Navara 06, X-Trial Sport 01 (CHNI3A) - Main harness including steering wheel control component
- Nissan D/Diversity Lead (AP348A) - For Antenna connection
Another reason for choosing this specific deck was because the LCD display can be completely changed in colour, unlike many that tend to keep part of the display/front in their corporate colours. There's a preset colour for orange that is close, but the User colour setting allowed for more finite control of RGB values (in 8 steps).
There might be better instructions around for the removal of the centre section of the console but I used a combination of photo instructions and YouTube video used for the Infiniti G35 (so assume its all the same for M35 Stagea and V35 Skyline):
- http://www.sound-rep...l-instructions/
The Clarion headunit itself came with a mounting cage, and after scratching my head a bit on how to use this, I realised I didn't need it. Instead, after unscrewing the factory H/U, I slid the Clarion in and used the same holes and screws to mount it up.
I was also hesitant as to whether this unit would be able to control tunes on the new iPhone 5, so I just went down and checked with the sync cable plugged into the USB connection (that was run over into the glove box for now) and all worked as expected. Win!
All in all pretty happy with it as is the wife unit.
Cheers
Brendan
Edited by VSPEC32
nice work. should have saved yourself the cash, got the Nissan to ISO harness, then cut the ISO plug off an attach that to your clarion loom. there isn't much room behind there, and those Nissan plugs are big. my clarion headunit had blutooth and ipod interface......... or was it JVC?
It was all plug and pray. I dislike cutting stuff up if it can be avoided. The expensive bit in this case was the Control A for Nissan harness as it integrates the SWC (Steering Wheel Controls) into the loom. A normal Nissan to ISO loom isn't that expensive.
In the case of the single DIN and the gauges above, there's plenty of space behind the gauges to tuck the excess wiring. The gauge unit is only 40mm deep max.
yeah I know, done it all before :)
that said, I realise I had a crap load of other wiring down there too, which would explain my lack of space.
glad its all working for you. not all that difficult is it?
Not really no. I was putting it off and putting it off, not wanting to stuff up the dash, but went without a hitch. Next up is to get the commsman cruise and steering wheel controls hooked up along with a factory reversing camera.
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
