EOI My Type X 180sx street/drift/circuit ($20,000)
Ben 0400705710
Brisbane
Mount Cotton
[email protected]
Bodywork:
10 piece GP Sports bodykit including metal widebody front gaurds
Roof spoiler and Duck tail boot spoiler
Koguchi Power bonnet
Ganador Mirrors
... Carbon fibre centre taillight Garnish
Interior:
Bride Zeta III Red Fixed back drivers seat with head pillow and lumber support cushion
Bride Brix II Red passenger seat
Nardi Deep Corn Suede steering wheel with NRG Tilt and short boss kit
Red Louis Vuitton Door cards and Glovebox
Defi water temp gauge
Defi Boost gauge
Blue led dash lights
Panasonic Head unit
Allpine speakers
Allpine tweeters
Apexi Power FC ECU with hand controller
Greddy Profec-B Boost controller
Pivot Headlight controller
Half Cage
Rear strut brace
Stripped and painted boot
Battery relocated to boot
Engine: (60,000kms)
SR20DET
S14 BB T28 turbo
HKS Actuator
6Boost manifold
Stainless Dump
3inch Titanium Pipes RC Exhaust
Titanium Cannon
Greddy Front mount intercooler kit
Oil filter relocator and oil cooler kit
Pod filter with Z32 airflow meter
Nismo 550cc injectors
Stainless catch can
Strut tower brace
Weld spark plug cover
NGK Iridium spark plugs
S14 5speed gearbox
2way mechanical LSD
S14 5stud
ABS removed
Steering rack relocated 25mm forward
Polyurethane steering rack bushes
Swaybars
Suspension
CST adjustable Coilovers & Shocks
Camber Arms
Toe Arms
Tein Castor Rods
Comes on staggered CST Hyper 01 17:18 9.5J +15
SERIOUS INTEREST ONLY PLEASE Contact for more info.
https://www.sau.com.au/forums/topic/416944-type-x-180sx-streetdriftcircuit/
  • 3 weeks later...
  • 3 months later...
    • Yep it sure does.   Tone wheel lines up in the same spot perfectly.
    • Something I meant to say when we were chatting the other night about having an open trailer floor being great to work on a car, but you've never used the feature... It's a great place to park a car after doing suspension component changes, and do the tightening of all the bushes with the car sitting at full ride height. Especially when you don't have a 4 post hoist!
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
