Your box fixed mark?
Yes mate, the only old bit now is the case, Award replaced all the shafts and gears and stuff, it was also modified internally to keep the oil from bring forced to the rear of the box which caused my problems of the gears not getting enough oil.
I'm in the process of giving it some love by cleaning the plugs and air filter, I'll swap out springs later as I need a large 90 deg straight edge to set cambers and I think I've lost mine somewhere.
My bloody camber arms are seized, camber will be around -0.5 instead of +0.5.
Yes, this is a preempted excuse.
Come on guys, get your cars out, lots of talk about big powered cars but not many are seen.
Broken cars or serious issues are fair enough, BUT, surely there not all broken.
Weather temps look good at this stage.
Mark go down to 17s work shop and flog some yeild.. or is the thread flogged...
If weather is better and I can get out of work early I'll come
Blue R33 GTR come say hello :)
Umair did you take your car to Yavuz for a proper tune yet :)
haha not yet trying to save some cash mate
had a boost leak when Yavuz put it on the dyno... bought a hard pipe kit and it pulls a lot harder now... keen to get it on the strip
not looking like I'll be able to leave work early though
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
