dw im not a wanker on the road :)
i had an s14 before this with 235rwkw 864nm and got raappppeeeddddddd on red p's..... i want this one to be as subtle as possible :) and im not gonna go for huge power..... might go up to a 2860 or 2871 with bigger cams and injectors when i get off p's :) hopefully get around the 250rwkw mark safely :)
  • Replies 45
if i can get more safely with that size turbo then awesome :) cause i dont want too much lag.....
and i like the sound with cams
you know, alot of the cam sound is from the tune, with mild cams its almost undetectable, but with the mixtures changed at idle you can get the fat cam sound or even without cams get the sound.
thats interesting! does it affect power or fuel safety of the engine?
i dont think so, its just the mixture on idle, obviously you need an aftermarket computer for that
with mine, as soon as the mixture was leaned a touch it would give the rough cam idle, but i prefer it with a smooth idle and odd lump to it.
Mark with your cams and turbo you should be making a bucket load more power than you are...why have it if your not going to use it.. most blokes with a basic hiflow setup would give you a run for your money any day...cams are not really needed in Rb25s unless your pushing for big numbers the stock cams are good to 350kw sometimes more...
yeah well with a forged engine im sure the gtx would make upto 380rwkw, i think if you run a gt30 or larger a set of cams doesnt hurt, it makes 320kw on 16psi which is nice and safe, i dont want to be doing a rebuild anytime soon, and yes they'd give me a run for my money cause they'd have more traction for sure, maybe in third id hose them off :)
You don't need a forged engine either....just a tuner willing to push the envelope. :P
haha , you go first then.. ill watch from outside the dyno room incase a pistons decides to depart ...lol
my turbo (actually my whole setup) isn't big enough, its pretty much close to maxed out as is....
but thats why i chose it cause it suits my power target...all i'm saying is why have it if you dont need it or not going to utilize it..
I'm not knocking your setup its killer, im just saying i want to see you turn the volume up..
It could be good for 400kw or you miay as well have got a smaller turbo ;)
yeah your 100% right, if i were doing it again id of just gone gt3076 maybe with a 0.63 rear even with E85 and hoped to max out at 300ish
went gtx cause it sounded like a good thing, 10%more flow etc but its actually suited for a forged motor really, but also down the track i would like to attempt a rb30/25 or maybe just a forged rb25 , so then the boost will be wound up to 25psi.. i like to have alot of room for more power down the track and really its not bad, 20psi at 4000rpm shes on par. ;)
we pushed mine to 21psi but nothing exciting happened...extra 10kws or something...have you tuned past 16psi at all, and is that on e85 ??
no havnt gone past 16psi at redline and yeah E85, it was responding very well to boost and timing advance, each psi was like 10kw or more and knock levels very low, the fuel makes massive difference went from 280 to 320kw with no more boost needed.
So did the tuner decide 320kw was the safe limit or did something else hold you back?
  • Like 1
well i asked him what he thought was a good safe limit and he said 1.4bar is what he'd take it upto on E85, i was only looking for 300kw so when it hit 320kw first run i thought, wow i think ill leave it there in case somthing goes pop... it must of cost about 5k atleast upto that point and dont wanna spend more if anything goes wrong..
Quite alot of people say running over 300kw's is a gamble so i didnt want to push it incase it went bang, and i love how it sounds and drives as it is..
sorry daniel , dont mean to take over your thread.. :/
Edited by AngryRBGTX
Mission accomplished then!! Still would be cool to just do a few dyno runs at 20+ psi to see what its fully capable of.
+1 ....and I'm intrigued to know why tuner didnt try it...if it was responding so well why give up on it....we all know an RB can push further, even if you just did it for tuning then cut it back....it also gives you a safety margin should you hit any overboosting issues down the track..I'd say 300 is a gamble but you're pretty safe on the dyno, its the varying conditions it sees in everyday life that would cause issues...
you could be restricted by that vegan clutch though....should of gone carbotic... :rofl:
+1 and I'm intrigued to know why tuner didnt try it....if it was responding so well why give up on it....we all know an RB can push further, even if you just did it for tuning then cut it back....it also gives you a safety margin should you hit any overboosting issues down the track..
im intrigued now too.. lol well it was with a 250kw rated clutch, ive no doubt it would of seen atleast 350kw, if you watch the dyno video you can see it backs off after 5000rpm so it had heaps left, i will eventually build a bottem end up and go back for 350kw plus its still a goal...
    • I know people cry at the price of the Getrag 12-14k for a conversion now, but it really is a nice mid point. Not going to get change from 10k on a gearset installed.  $30k++ for sequential.   I know you run the risk of a damaged used one and parts are hard to get but as a street car gearbox its really hard to beat. If you enjoy a more traditional manual, its the choice no question.
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yep, its been down for a while, as I understand it it will be back soon.
    • Yeah I also looked at Plazmaman, but, it ended up alot  cheaper getting black ones through EFI when you also added in the delivery cost
