Hi Guys,
This is my first post here but have been reading for a while, so hi all :). I'm currently looking at a stagea with a broken electric seat (I understand this is a pretty common issue). It's a 2002 NM35 Autech Axis with the heated leather electric seats, I just wanted to get some opinions as to common issues/fixes for this problem. All other functions appear to work except for the back and forth motion (the only one you really NEED haha, typical). Does anyone have any experience with this?
Thanks in advance!
It will just be dirty terminals. You can sometimes get away with just spraying some cleaner in from above. But your best bet is to pull the seat out and disassemble the switches and clean them properly.
  • 7 months later...
I know it's a long shot, but is there any chance you still have the spare motor & you want to sell it to me? :) Pretty sure one of mine has had it. Already blasted the switch, can hear the motor itself trying to switch on, but it's just not moving the seat!
    • So I actually had the cover off my car today, here is a (bad) pic of the setup. I have an oil cooler thermostat block, the temp sender is straight in there. The pressure sender has a short AN line to a T piece which is mounted (hopefully cable tied counts as mounted....) on the chassis. BTW every fitting you could ever imagine exists....just depends what they cost and how many you need. Raceworx AN adapters are here: https://raceworks.com.au/fittings/adapters/, I think you said you need BSPT to AN (https://raceworks.com.au/fittings/adapters/bsp/tapered/an-to-bspt-adapters/) and AN to NPT (https://raceworks.com.au/fittings/adapters/npt/) BTW, braided line is super simple to make. It looks intimidating, is not.
    • Perfect day for a pie, really needs a soft top in this weather though
    • Prime parking, she is a little girl...LOL
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
