  • Replies 62
Hi.
Pic of NUR carbon OEM bonnet, front bar and middle lip. Pm or call/sms
Alex 0433878905 Items are in Braeside Vic 3195
Hi.
Got a 400R copy new front bar with indicator light and grill, pair of side skirts and rear pots, unpainted to suit GTST 33.Won't fir GTR33.the set for 750. will take pic if required.Thanks for the PMs
The 400R front bar will fit GTR 33 with a GTST reo support, the rest will take a lot of work to make it fit GTR. Here are the pic
Do the have model numbers on them? Do you know the spring rates? And lastly do you know how many kms they have done.
If you have better photos let me know and I will pm you my e-mail address.
Selling a pair of Bride style full bucket seats brand new with head restrain wing stays. comes with driver side rail to suit Silvia and GTRs. Too wide for me even I have got some extra velco paddings. See pics.
No passenger side rail. only borrowed pax rail to trail fit
$1200
prefer Melb. pick up
You wouldn't have a rear diffuser laying around to suit a r33 would you?
Got a slightly damaged one , repaired and ear marked for my GTR33 track car.
there is one similar to mine in Adalaide.
Got a big aero front bar with split for my S15 , like to get some sort of rear defuser to match
cheers
My spare BM57 has gone into the S15 track car to feed the upgraded GTR33 Brembo. Original S15 master don;t match the GTR front brake, too spongy. Once I put the BM57 on it , all good, pulling my eye balls off!!!.
Can source a BM57 for you
0433878905
Alex
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
