So these "attacks" are being caused by someone? Or bugs/viruses? Combination of both?
Can it be tracked or something?
Not too clued up on this type of thing but if someone needs a gearboxing I'm sure it can be arranged, I have one on standby :)
Generally attacks are scripts / bots that scan for websites or predefined websites (off a list) for predefined values or text ie: ipb3 (forum software) then try to hack various parts (vunrabilities) / exploit various bugs within their software to do anything from posting adult websites, promoting other websites gain admin access (for mailing lists, user details) etc.
Most of the time pain to track because they use anonymous ip software / servers or other hacked computers etc.
Yeah mate, Invision released a patch today that (I believe) addresses this.
I'll be applying it tonight. There'll be no downtime as it doesn't contain db changes.
thanks mate.... had to go to my content to find what you posted as i couldnt click the notification or look at the new posts...
I owe 2 peeps Feedback now and I can't do it.
Leave Feedback doesn't come up as an option in a users profile anymore. :(
Little Help?
I dont know what the hell you are talking about ... its been there all along....
:unsure:
:yes:
:unsure:
:yes:
post-78856-0-20145000-1361962224_thumb.jpg <<<------------- This is very odd indeed. :yes:
Edit* Leave Feedback is Back!!!
Thanks Christian. :) You is da Man !!! :D
:unsure:
:yes:
Lol a mate left 2 Neutral feedbacks being a smartass, can you delete them off my profile and ill bitch slap him? Making me look bad :blink:
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
