Bah, not a problem if you keep it clean.
So tiny update.
Scored a fenix replacement radiator, nothing special just OEM. Gotta change belts and cabin air filter so a fun weekend is coming up soon :D. Also might clay bar and wax the car if I can be f**ked.
https://www.sau.com.au/forums/topic/417327-my-pnm35/page/6/#findComment-6933910
  • 2 months later...
Shift kit is in!!
Cheers to Jetwreck!! :D
Also found another missing nut, this one was from my rear swaybar. The cause I believe my driveway with its serious angles is causing massive stress on the bracing and bars. So, locktite and lock nuts ganna go on and ganna be tightened. Hard.
But the shift kit is awesome!! Hard as f**k shifts and chirps :D:D Love it. Also transgo shift kit sticker on trans sump because #shoppinglist.
https://www.sau.com.au/forums/topic/417327-my-pnm35/page/6/#findComment-7053594
Nice ride man. I also got a White Axis Autech and i really love it :woot:
How about the sound with the new exhaust?? I got a Nismo cat-back system on mine but it soo silence :(
(sorry for my bad English)
Cheers.
It sounds OK, some bits I love some bit I don't, has a bit of drone. LOL! If I could have gone NISMO I would have but this came up cheap.
https://www.sau.com.au/forums/topic/417327-my-pnm35/page/6/#findComment-7055206
I also have nismo. They are way to quiet but atleast the police stay away :D
https://www.sau.com.au/forums/topic/417327-my-pnm35/page/6/#findComment-7055220
The NA VQs are quite a bit louder than turbos.
My car is louder as a NA, then when it had the turbo as a restriction in the exhaust. This is with the twin square style Nismo 3 inch. Dont forget there are more than one nismo exhaust. The other one is a single outlet, 2.5 inch, and is really really quiet.
https://www.sau.com.au/forums/topic/417327-my-pnm35/page/6/#findComment-7055232
Camera ---------> cash converters ---------> moar Jim Beam colas!
Dat Western Sydney Lyfe
Wrong.
Smash camera with bricks, take bricks to cash converters threaten cashier with bricks, takes munies then profitz.
Edited by M35woah
https://www.sau.com.au/forums/topic/417327-my-pnm35/page/6/#findComment-7055479
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
    • Did you hit up the search function? R33 and greddy and cable returns this thread with some options.   https://www.sau.com.au/forums/topic/358214-rb25-throttle-body/
    • Thanks buddy.. the standard one needs to be about another inch or inch and a half longer. Thanks anyway
