  • Replies 138
Have seen pic of wife, Luke's done well for himself lol.
Move to Toowoomba, it's beautiful ;)
And the biggest and may I add only point you should need is the fact that I live here, and the TSO boys always put on a mean feed and piss up (usually utilising Chris's house with attached pool)
... *although Tom (Tommis85) is the only one that swims in it, the rest of us are usually to drunk
Just move you won't regret it :)
You need a reason to come to the most laid back state in australia? Come on mang, srsly
If you want to make bulk money and can handle big hours, come on up, but i can almost guarentee that julia gillard will be sending you a xmas card funded by the tax you are giving her. The weather isnt as bad as some people make it out to be, i grew up in the centre of australia (near three ways road house on a cattle station) and that is hot lads, farkern hot. The beaches are kick ass, the pubs are kick ass, the lifestyle is kick ass, the locals are kick ass(mostly), and the monetary opportunities are kick ass. There are almost infinite holiday destinations at your doorstep as the country north of mackay changes yearly with the weather, you have the reef, awesome fishing, just yeah, stop bieng a phaggot and get up here lol. The only thing you may miss is the shopping and nightclubbing, its not as intense up here, and thats because nobody really gives a fcuk up here lol!
on a serious note though...
Brisbane employment is getting harder and harder due to all the Campbell Newmann cuts and general economic slow down.
Humidity rarely drops below 103%
GC is full of crime
The entire 2 weeks of winter gets pretty cold in Brisbane... well you'll think so after about 2 years up here.
I did the same as you are thinking back in 2006.
Do it..!
get a job offer before you move, obviously.
Southside of Brisbane generally has good transport due to some rather nice freeways, north and west side, not so much.
The racetrack isn't a good reason to move to Ipswich (its out of the city anyway), but houses there are cheaper, and due to the better new roads its not that hard to commute to the city from it.
was born in bris, but have have lived in most states in aus, ippy is the worst place iv'e called home accept for canberra. GC hinterland, maroochie coolum, happyrock is my pick, further north and you need a high tolerance to heat and bitties/ stingies
Mike.
will look into these places.
sorry ...
replace happyrock with maryborough
this was one of the places we were looking at.
Hot wheat her means that wimminz wear less clothing....
What sort of job? I work in recruitment? May be able to help. :)
am mechanic, but not sure if i want to stay in this profession.
im sick of the crap you have to put up with.
Whooaaaaa hold up!
Canberra isn't that bad haha
think of it this way.
you think you gf's hot?
date a lingerie model, then look back at your current missus.
and you will know what its like to leave canberra.
*note, i have not seen your missus, its just a comparison, meant for a laugh*
dont club, so that wont phase me.
i dont mind shopping, but alot i do online.
im more concerned about the heat and humidity.
i farking hate heat and humidity.
and its more the missus that wont leave sydney at the drop of a hat.
im pretty keen to make our way up there.
would have to organise jobs, and sell our house/pay off loan/apply for new loan for house where we want to move to.
Humidity is the killer, we normally average around 30 deg. in summer and 20 deg. in winter. Sydney and Melbourne get more and longer heat waves than we do up here. Where abouts are you thinking of moving to? Greater Brisbane or one of the northern towns?
not sure, I like the SE corner.
but I also want to stay with range of at least a drag strip.
I like keeping my antics off street.
Well I'm at the very north end of Brisbane and it's about an hour drive to the nearest drag strip, Lakeside is about 5 minutes up the road and the 2 best mountain runs are only about 15 min away. So within greater Brisbane you will be about 1 hour from the drags.
Yah stay north side...don't let anyone talk you into going south of that river ;)
Seriously though, keep out of Logan and the west or have a very serious amount of security on your line.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
