Hi,
Its time to sell my R32 GTR.
The engine has recently been rebuilt in 2012 and has only done appox 2000kms (Run in properly on dyno). This was rebuilt by Dan at ERD (Elite Racing Developments) and has been tuned by Sean at EFI Performance over the last couple of years.
Car:
1990 R32 GTR
92000 kms
Gun Metal Grey
Engine:
Cosworth 87mm Forged Pistons
Manley Forged Conrods
New Nissan R34 GTR crankshaft
Reimax billet oil pump
Tomei sump baffles
Tomei oil restrictors
ATI Dampner (1000hp)
Tomei 1.5mm Head Gasket
Trust timing belt
Kelford 282 cams
HKS cam gears
Manley valve springs with Titanium retainers
ARP head studs
ARP main and rod bolts
ACL race bearings
Turbonetics GTK 1050 billet turbo (twin scroll exhaust housing orderd direct from turbonetics)
6boost twin scroll manifold with EGT ports and silver ceramic coating
TUrbosmart 60mm Powergate with 3 springs
All braided hose and AN fittings to turbo, wastegate and boost controller
2.5 inch screamer pipe
4 inch dump pipe
decat pipe (no cat)
3 inch catback titanium exhaust (straight through)
Greddy plenum (welded and painted black)
Greddy plenum 100mm pipe kit
100mm Intercooler
Alloy radiator
Header tank setup
Front mounted oil cooler
Front mounted fuel cooler
Custom catch can setup
Remote oil filter kit
Nismo oil cap
Nismo radiator cap
Nismo thermostat
Nismo engine and gear box mounts
N1 water pump
Ls2 Truck ignition coils
Fuel System:
Bosch 044 lift pump intank
7.2 litre polished alloy surge tank
Magnafuel 750 protuner fuel pump (2000 hp)
Inline filter
Twin entry fuel rail
Bosch 2200cc injectors
Aeromotive FPR
Fuel cooler
All braided hoses and AN fittings on fuel system
Suspension, brakes wheels:
TEIN HA coilovers
Oversize front and rear sway bars
Rear suframe lock kit
Castor arms
Dba 4000 rotors
"Race Brakes" pads
19x9.5 Axis Hiro wheels
Federal 595 265 35 19 tires ( less than 2000kms)
Interior:
Power FC DEjetro
Cusco 6 point roll cage with bolt in intrusion bars (mod plated in qld)
Sparco steering wheel
Greddy water, oil temp and oil pressure gauges
DEfi boost gauge
Defi controller
Pivot shift lift and controller
Torque split controller
Nismo instrument cluster
Blitz Dual SBC type R boost controller
Nismo floor mats
Exterior:
Ganador mirrors
Smoked front indicators
HID headlights
N1 Headlights
Trust front bar with vents
Probably plenty more parts I have forgotten to list
Tuned on Caltex Eflex (can be converted back to pulp with a retune)
AC has been removed to fit oil and fuel cooler (can be reinstalled I have all parts)
Currently it is reg in Qld i will be selling unreg due to the high level of modifications
Price:
$32000 neg
Brisbane
Contact me on 0433587235 or pm me
https://www.sau.com.au/forums/topic/417382-r32-gtr-490kw-for-sale-brisbane/
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
    • I definitely know the first rule here, look first, ask second. I've seen many people get roasted 😂 I found a few diagrams for the RB, but I'm yet to come across one for the VQ. From what I have read, the pump gets the +12v along with the FPCM, and it's the negative wire that gets passed through the resistor to regulate the voltage. So I assume I can just ground the negative wire at the pump to eliminate the FPCM control. But I really wanted to see the VQ circuit diagram first to make sure I understood it correctly. Once the new pump is in I'll do some testing to see how it behaves, and in the meantime, I'll keep looking for a wiring diagram. Thanks for your help mate, your time is greatly appreciated.
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
    • I used to do that (sills with rubber jack block).. ... then I got side skirts, and there's no way for the jack to actually work there, the jack pad itself on the jack is too big. Is the answer to use a... smaller (?) jack? Hmmm.
