Hey guys,
I am looking for some dyno time just to do some of my own tuning after installing some mods, I vaguely remember a mate doing it years ago on a dyno just off main north road near blair athol.
Anybody know the place, or know of a place that might let me do it ?
Not looking to book the whole day or anything, just a couple of hours of time to play and then a power run at the end.
https://www.sau.com.au/forums/topic/417474-dynos-in-adelaide/
Hey guys,
That would have probably been Road & Track who were in Collins street, Enfield for a fair while. Unfortunately Gil has retired and the business is no more.
-D
The only dyno off Main North Road at Blair Athol was Road and Track. Mike Dale used to be the dyno operator, now running his own business at Holden Hill, Mike Dale Automotive. He doesn't have his own dyno, but I know he uses someone elses much the same way as you're looking to do. Can't remember who he uses though.
Behind Maccas at Enfield is Scorpion Tint.
steve knight racetech at 8 walla ct lonsdale , very cheap and ex head ralliart mechanic, good bloke and too honest for his own good..cant reccommend highly enough. and competes in the wtac. hes got a mental evo6.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
