Anyone Know How To Lock The Aircon To Produce Cold Air Only? (As In Mechanically Or Heater Hoses, Etc?)
Hi everyone,
My blend door servo is still giving me head aches, so instead of trying to sort that out for the 3rd time, I wanted to know if anyone knew how to jimmy the aircon to just produce cold air?
I remember reading on a past thread that someone managed to do so by taking out a heater hose or something in the engine bay or possibly re-directing one to just allow cold air to flow? (can't find the thread anymore :( )
Anyway, if anyone knows anything about how to do it or know's a link of how to do so, that's be great as i'm tired of hot air right now lol
thanks
meta
Looping or blocking the heater hoses off may produce cool air, but may produce ambient air temperatures
if your already playing with the blend door, cant you just zip tie it in the cold only position or something? That is the easiest thing to do.
Lol, i've actually zip tied the blend door to cold already, but i'm still get warm air
Pop the cable off the water valve and keep it in the closed position
thanks mate, and i hate to sound like noob, but where is that located lol... i'm just being wary to tread carefully, i've had enough mishaps lately lol
Removing heater hoses wil give judt cold air. Did it on my r33, seems a/c mixes hot/cold to regulate temp so just cold will give exactly that.
Is that cold as in "Cold" aircon? or just ambient cold air?
If you've got the flap locked to cold only, then the reason you are only getting ambient air is that your aircon may be low on gas. when you turn the aircon on, can you hear the compressor kick in? Is the aircon properly cold when the engine is cold but gets warm once the engine does? if the compressor doesn't kick in then its probably low on gas. If the aircon starts off properly cold then heats up then its the heater tap.
the aircon was recently serviced and also re-gassed, so i'm assuming it's not that
The compressor does engaged and works fine, what i'm finding is that once the aircon is on, it just blows ambient air, which rises stays at a constant warm heat.
It was working perfectly fine prior to my blend door servo motor dying
I had an airconditioning place remove the motor and "apparently lock it" in the cold position, which doesn't seem to be the case :(
as for the heater tap? sorry, you may have to explain this one too me sorry lol, not good with aircon
If you have zip tied it so the blend door is in the full cold position and ur not getting cold air then you have a problem. Are you sure its in the fully cold position?
And yeah see if your AC compressor clutch is engaging. Should be able to see the front of the compressor stationary then start spinning when the AC button is pressed on
the heater tap is to do with the coolant entering the heater unit. basically, when you turn on the heater, the tap opens and allows the warm coolant to enter the heater core. if the tap is dodgey then you will have coolant circulating through the core all the time, but this shouldn't affect the air temp too much unless the flap wasn't fully set to cold.
I was under the assumption that it was, however, since i haven't had the time to pull it out, i've decided to just take it to another airconditioning place to sort it out
As for the AC clutch, it does engage, the whole system is working fine, just not producing cold air lol
thanks for the reply mate, I'm having it checked out today, so i'll repost when (hopefully), it gets fixed, hopefully this post will help someone later in the track
Just had it checked, it was the air compressor :(
Now does, anyone know where i can find brand new air compressors for an r32 gtr? and if they're exactly the same as the normal r32 gts-t?
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
