friend of mine got under the back of my recently acquired R33 and we found out the hicas has already been removed (winning) He also said its not an R33 rear end or it has been modified alot.
I have never actually seen under the back of an R33, I know someone modded lots on this car many years ago it was actually originally an NA Auto GTS but has been modded to be RB25det 5 speed - has 2 after market swaybars under the front as well as many non standard suspension parts, abs has been removed as well ... not sure about this rear end though .... does it look legit to anyone in the know? The diff seems very tight and makes some funky noises at full lock so it may have some internal damage but no noise for usual driving. Sorry if the pics are not enough I dont really know what I should be looking at when it comes to rear ends apart from the obvious parts. IF anyone could help me ID the origin of any of this and how much is non standard that would help me out lots!
Obviously the coilovers and exhaust but apart from that Im not sure
https://www.sau.com.au/forums/topic/417631-newbie-help/
Pretty sure NA 33's came out with non hicas rear ends.
As for the funky sounding diff, could possibly be a mechanical LSD in there
ah that would explain it, how do I tell if its mechanical lsd? I am guessing jack up and spin wheels but what am I looking for?
https://www.sau.com.au/forums/topic/417631-newbie-help/#findComment-6704601
yep no hicas rear end...nothing to worry about there..
as for the clunking at full lock that is perfectly normal for an mechanical LSD or locker...sounds more like a LSD tho as a locker is alot harder to live with on the street. jack it up and spin the wheels is one way and the only way without taking the cover off or diff out
Edited by Frosty
https://www.sau.com.au/forums/topic/417631-newbie-help/#findComment-6704925
Yes, but if it happened to have a viscous LSD in there that test would work the same. So not a definitive test. But a VLSD would be so "invisible" in normal use that you would never hear it clunk and carry on in tight corners unless it had been shimmed massively.....which is also possible I suppose, given the daft approach many people seem to have towards VLSDs.
Otherwise, I concur with what has been said above. Original NA non-HICAS rear end in that car. Surely that is the only good thing about starting with an NA car.
https://www.sau.com.au/forums/topic/417631-newbie-help/#findComment-6704986
i agree mostly but 2way mech will clunk aswell so it all depends on the how its been set up and the only way to know is take it out which im sure he doesnt want to do
https://www.sau.com.au/forums/topic/417631-newbie-help/#findComment-6704997
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
