Parting out my r32, all parts located in Homebush NSW, pickup preferred but can post at buyers expense. Engine is still in car can remove for $100 extra otherwise can supply crane. Car is almost complete anything ive missed feel free to ask. Will post pics on request.
Power Steering pump rb20 - $50
Power Steering pump rb25 - $50
Power Steering rack - $100
3 Inch catback exhaust - $200
Front head lights like new - $140
Indicators like new - $50
Tail lights like new - $200
A/C gear - $100
Alternator - $50
hdi dual sbc electronic boost controller in ashtray never used $120
centre ac vent brand new $100
front seats $150
rear seat $60
climate control unit $50
boost, exh gas temp and air fuel gauges in centre dash piece (centre piece has broken shifter surround) $140 for all 3
rolling shell ( comes with wheels, suspension, brakes, tailshaft, full aero kit including original sideskirts and interior minus centre ac vent, no seats, no centre dash surround/centre console, no climate control unit, no parcel tray wooden piece or fuel pump. will come with power steering setup unless sold earlier in which case will drop price. $1700
rb25det with rb20 gearbox and exedy hd clutch (no turbo, fpr, inlet pipes, power steering belt) $900
sard fpr $140
hpi clutch cable (eliminates slave cylinder) never used $100
walbro gss 342 fuel pump never used $90
motec m48 clubman ecu upgraded to latest software $1500
motec ignition expander $120
all prices neg. no low ballers please.
Edited by brendo.r32
https://www.sau.com.au/forums/topic/417824-r32-4-door-gts-t-part-out/
dude what a shame to see this being parted out... I've been keeping an eye on it for a while but unfortunately your to far away for me :(
If I had a car trailer I would come and take the whole thing
anyway good luck with the sale :)
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
