  • Replies 51
Hit up streeter to source you one
best guy can gets his hands on some pretty rare stuff, and had probably the best reputation of anyone as a broker, been round for years. Ive spent 15+K through him
jessestreeter.com
Totally agree, he was my first thought, sent him a message earlier. True to form, he's already contacted URAS and requested an eta for delivery.
I have a feeling I will be really really low, so I'll probably make a quick release bracket so i can drop it out easily if needed.
Could it be something like this one you are after? Just a tiny lip..
http://www.ebay.com/...984.m1423.l2649
Yeah I'm a bit sus of the rubber lips, but they don't look to bad in some of the photos, reminds me of a Rauh Welt valance...
I like the ones that mayo and DG35 posted.... but theyd last less than a week on my car before getting wiped off (and my car is not that low either). Has to be the rubber lip for me
Edited by Deep Dish V35
Anyone know where to get this splitter?
These come from here
http://conceptautomotive.net/product.php?productid=16195
I'd be interested in splitting postage with someone if keen?
Checked out this carbeer I bought mine, had this front lip which looked factory and didnt kick forward as much as every aftermarket lip, it also had the pods/mudflap things
The car next to it had the exaxct same lip too....If its not OEM someone tell me what it is as I want it and havent seen it on any of the american sites
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
