Water Pump Pressure Readings?
I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
