I've been searching for the past 15-20 minutes trying to find more info about motorkhana builds for 32-Rs.
I have a 89 BNR that I'm going to send over the USA eventually. It's very much stock except for a few bolt-ons, etc so I don't want to modify it much (stock 32-Rs are getting rare). I decided to run motorkhanas because of the ability to have fun while not causing too much stress on my old GTR.
From searching on SAU, I see that hardly anyone races their GTR in motorkhana. I found more that GTS enjoy the sport as opposed to Rs. It seems that more GTRs are rally'ing, road racing, etc.
I don't mind road racing (HPDEs in USA) in 'stock/street' class either but motorkhana is a lot cheaper and more accessible so I'm leaning more towards that.
Is the GTR a bit of overkill for motorkhana?
Should I just focus more on a road race build?
https://www.sau.com.au/forums/topic/418143-motorkhana-bnr32/
well, unless I misunderstand autocross is a bit quicker and more open than our motorkhanas, so it won't be so bad. They are a little large and heavy for local khanas, but still great fun :)
In the end, you'd still get eaten by an evo or some sort of mini special
Thanks, mate.
I've done autoX'ing in the past and loved it but I suppose it's not as popular in Oz like it is in the US. I remember a lot of younger guys were autoXing and usually the older drivers were doing HPDEs
No way overkill! I've competed in GT-Rs for the last 18months at our Vic SAU days (max speed is around 140, avg about 60-80) - and the GT-Rs go just as well as the 180s etc. Just gotta learn how to drive them and set them up really.
Good diffs, suspension & brakes will make the world of difference. Of course power will also help and either way if i was you - change those turbos before they fail and potentially take the motor out.
For a good khana setup if you put on say:
Garrett -7s / PFC/ Tune
Nismo Diffs & transfer case rebuild & a high volume sump
18s or 17s with good rubber
Brakes (perhaps the GB? Link in sig)
You'll have around 300rwkw, and it will be super responsive & nimble (well, as nimble as a GT-R can be) and handle like a RWD or AWD car as the diffs lock hard and are good for tight stuff to get the ass around and then straighten the wheels and bury the pedal and 4 wheels drag you out :)
I had larger -5s but for that type stuff on a 2.6ltr they are too laggy.
You saying you competed in morokhanas? I'm not sure what Vic SAU days are.
I definitely want to setup the GTR for maximum grip while still maintaining the originality of it.
Thanks for the build-list. ATM, I'm think about doing a simple 33-R brembo upgrade as opposed to anything to crazy.
Just youtube "SAU-VIC DECA" - there will be heaps of footage of skidpan and also the back-track type stuff. Not your traditional stuff, little more speed involved but I managed to get a R33 around pretty well when i remembered which way to go :merli:
33-R brembo's are overpriced and a waste by the time you get new rotors, pads, rebuild (and paint) the calipers etc.
^I can get them fairly cheap in Japan. Believe it or not but I have a set of front R34 Brembos before I found out that I would have to drill a larger hole. lol.
I watched the videos, mate. Thanks for the info. ;)
Back on the subject of racing the GTR. What are some good engine supporting mods that I can do to help the engine longevity? For example, oil sump, ceramic coat the block, mine's cam baffles, Tomei oil orifice, etc. I want to keep everything stock but I do want to add lots of supporting mods.
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
