Hey guys,
Well the old girl has given up compression on no.6.
1989 model. Imported/complied in 1999. Gunmetal grey.
90,000km on the motor.
'94 model engine so has long drive crank.
Timing belt/tensioners/water pump (n1) and oil pump (n1) done as well
HKS oil cooler kit with filter relocation
Tomei sump baffle
Profec B spec 2 electronic boost controller
Nismo cluster (so can't be 100% on kms however in very good condition)
Nismo rear subframe (stiffer bushes)
Nismo billet flywheel and button clutch (balanced) Plenty of life left - only done 5000kms
Nismo shocks and springs (firm without being teeth chattering)
Newish genuine radiator
R33 GTR brembos all round with plenty of pad
Wedsport 17" lightweight wheels. (unsure of exact model but can chase up) -so light you can juggle them
Bee R front pipe
Full exhaust
Sounds the goods (less so now that she's low on comp)
Sure i've forgotten lots but it'll come to me.
Body quite good. Has had a respray since coming to Aus. Few scratches and what not but she's 24 years old!
Interior good. 1 tiny mark on dash (not a bubble)
Nismo gear knob
Momo wheel
GPS based alarm with satellite tracking
Sony head unit
Has had oil/filter/coolant/fuel filter etc in last 200kms.
Heaps of hoses replaced under the inlet manifold and also replaced water fittings and other little bits and pieces.
No leaks.
Has rego till November 2013.
Its a great car that just needs the motor freshening up and will be a joy for a new owner.
If the price is right i can include a a forged bottom end that is ready to be put together and lots of spares. (power fc, turbos etc)
Will get some pics up this weekend.
$16000 happy to negotiate with serious people. May seem a bit dearer than the rest but at least you know what your'e gettting.
Located: Castle Hill
Cheers
Luke
0422 729 679
Edited by piranha
  • Replies 48
Yeh I realise that.
But if you buy a 32 gtr in any condition with a std engine you really have to budget in a rebuild.
Best to know before you buy I reckon.
Like I said happy to negotiate and listen to any offers.
Its not a rusty bucket with a basketcase of problems like all the other ones selling for really cheap.
You make a good point with the shell being rust free, but regardless it's a blown engine worth nothing which you can keep. And you won't find anyone paying 16k for a rolling shell and as much as your negotiable, I'd be guessing a thousand bux if that is all you'll negotiate. I know you just want to try make most the money you paid back but there was an immac rolling shell r33 GTR registrable sell for like 5k which was just missing running gear. I'm just being realistic with you.
I can do it as a rolling shell for a lot less if someone wants it that way.
It would be a but of a shame to see it stripped and tracked though.
Anyway, see what happens. If not it will go in storage till I can get some time to work on it
I had a car that did that. I pulled the head popped the sump pushed out number 6 piston, and re
Ringed and honed it. Since then the car is running perfect compression for years. Have to set the right tolerances but !
Will do $15k as is including power fc and hand controller.
Still trying to work out a price without motor.
Can also do cheaper without wheels.
I'm talking with a couple people about the shell.
I will have to wait and see if they want the loom in it.
As soon as I know something i'll let you know.
Cheers
    • Well, yes, every CU on the bus is available via the Consult port, but whether the scanner you are using is capable of talking to the TCU, the ABS/TCS modules, etc etc, is what is at question here. Many of them are only for engine codes. So, if you have one of those, you won't know if the ABS is having a bitch.
    • That's now. R chassis Skylines come from a time when the tolerance in the ADRs was a bit more....slack. My car, on 235/35-17, which is damn near the exact same size as the original 205/55-16, is pretty much bang on correct indicated speed across the whole legal range. That's demonstrated with constant speed run over 5km, and GPS speed. It's just the luck of the draw. My particular speedo head has to be the thing that is "calibrated" that way, because everything else (the diff ratio, the gearbox and the speedo drive**) are all same same as most other Skylines. **OK, so the speedo drive is a Navara unit to drive the R32's cable, not the electronic unit than an R33/4 would normally have with teh same gear on it. Otherwise, I applaud your OCD tendencies, and I would do the same if I needed to.
    • Not too sure, I believe the Nissan consult port does everything? Also just filled up the reservoir to full and the light is still on. The float seems to move up and down fine.
    • The speedo's can be very conservative, when my Mazda NC MX5 speedo is showing 118kph, the GPS, and a calibrated radar.... cop mate.....hits me at around 110kph +/- 1 or 2 kph, and that is on a 215/45 17, stock tyres size is 205/45 17 as well, so weirdly conservative with stock tyre size When my Commodore speedo red 116kph GPS had me at 110kph on 255/40 17, so again conservative Google says manufacturers need to set the speedo from 4 to 10% slower than actual road speed.....for safety.....and compliance  After doing some offset and clearance measurements to see what can fit the NC on 17x8 +40, without guard rolling or rubbing anything at my current ride height, I've decided that when my tyres are toast, I'm going to fit 225/45 17 and see where that gets me IRT actual speed of my speedo and GPS/radar From the online calculator I should be still be doing around 5kph under an actual 110kph when the speedo is showing 110kph My ADHD requires that when I'm doing 110kph on the speedo, that the actual road speed is actually really close to that, and not alot slower And going from 205 to 225 still keeps the car within the %/mm allowable in the NSW vehicle rules and regulations, which is nice, as long as I'm looking at the latest version that is.....LOL https://www.nsw.gov.au/sites/default/files/2021-02/RMS-13.464-Light-vehicle-modifications-Vehicle-Standards-Information-No-6-November-2013.pdf
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
